Oberheim Matrix 1000 Control/Editing
- supermel74
- Senior Member
Can the Matrix 1000 be realtime controlled/edited with a standard hardware midi controller like the Behringer BCR 2000 or can it only be edited via software?
- No Longer Registered
I have a 6r and it doesn't take kindly to CC control at all. Especially with the envelope. It stutters and sometimes locks up for short periods.
I've heard that Sysex controllers will work more smoothly. I don't have one to test though...
I look at my 6r more like a preset synth than a real-time synth. It'll do some crazy s**t though.
- xpander
- Gear: UltraProteus, Xpander, 200e, Minimoogs, Radias, Prophet VS, PolyEvolver, Arp 2600
you have a couple MIDI CCs you can assign into the modulation matrix, seen in the screen capture below of Unisyn and then Galaxy. it also responds to SYSEX control (that's how software editors work, of course)... but i still need to program a realtime example to see how practical it is. i have had much success with MIDI CC control in the mod. matrix.
- supermel74
- Senior Member
- vcs3
- Gear: BitOne,DX7II, M-1000, ESQm, Procussion, NanoSynth, VL1, P2500, K5000R, FS1r, JX-3P, Ju-60,HR-16, CZ1000, RX-5,K2600S, Nord G1r, G2, XL-7, Shuthri-1
Re: Oberheim Matrix 1000 Control/Editing
Yes it can.supermel74 wrote:Can the Matrix 1000 be realtime controlled/edited with a standard hardware midi controller like the Behringer BCR 2000 or can it only be edited via software?
And if you use this software http://www.mk2software.com/matrix/index.php is a piece of cake.
P.S.- I don't know the guy that make it! I'm just a costumer.
- Joey
- Gear: 18u Eurorack, Octatrack, Pro2
- Band: BLUSH_RESPONSE
I belive theres also an access programmer available for it, should go for cheap on ebay.
http://wearereplicants.com
Um, they are rare as h**l and sell for more than twice that of a M1000. There is nothing that works well with the M1k/M6 as far as comprehensive realtime controls go since the processors cant handle large midi streams and choke. I spent days trying every possible combination of hardware and software to give my m1k some form of control surface and everything had the same results. The only thing that did work for any usable realtime control was using the assignable CCs as modulation sources. Anything sysex would only allow adjustment of parameters one at a time and with no notes playing. If you played a note and tried to tweak a parameter via sysex, it would freak out.Joey wrote:I belive theres also an access programmer available for it, should go for cheap on ebay.
- Joey
edit:Altitude wrote:Um, they are rare as h**l and sell for more than twice that of a M1000. There is nothing that works well with the M1k/M6 as far as comprehensive realtime controls go since the processors cant handle large midi streams and choke. I spent days trying every possible combination of hardware and software to give my m1k some form of control surface and everything had the same results. The only thing that did work for any usable realtime control was using the assignable CCs as modulation sources. Anything sysex would only allow adjustment of parameters one at a time and with no notes playing. If you played a note and tried to tweak a parameter via sysex, it would freak out.Joey wrote:I belive theres also an access programmer available for it, should go for cheap on ebay.
I didn't realize they were that rare...
I was able to make a semi usable M1000 editor for the Access Virus TI using sysex. Most parameters adjust fine without clogging the buss, but sometimes it chokes. its too bad that you cant thin the amount of sysex going outbound, or it might work. as i read on the internet, its possible that the sysex was incomplete, as in unfinished on the oberheim mfg plant.
i also bought the ob6000 for it. thats pretty great, but still has similar issues.
pm me if you want it.
doepfer modular, moog rme, cwejman s1 mk2, virus TI Polar, nord modular+G2, kurzweil K2500xs + RS, e-mu proteus 2000, alesis andromeda, dave smith prophet 08 rack, arp avatar, octave cat, emax, speck xtramix
The sysex is about as simple as it gets (very short string, one variable per control) and I think the midi implementation is wonderful since you can control any parameter possible. The problem is the hardware cant deal with sysex messages and normal note data at the same timesoundsubs wrote:I was able to make a semi usable M1000 editor for the Access Virus TI using sysex. Most parameters adjust fine without clogging the buss, but sometimes it chokes. its too bad that you cant thin the amount of sysex going outbound, or it might work. as i read on the internet, its possible that the sysex was incomplete, as in unfinished on the oberheim mfg plant.
- shaft9000
- Real name: Dave
- Gear: Whips chains waxes oils dildos DMT TNT the LHC, and a black rubber duckie
- Band: moneymoneymoney
i adore the sound of this synth despite it being a turd to program.
just lovely pads, odd keys, strings & fx noises.
it's the only synth i've ever kept that is lousy to program (ROMplers included)
long attack EGs absolutely rule the universe
i can only imagine how delicious a Matrix12/Xpander must be....
Sysex strings can be but on the m1000 they very short (i.e. F0 10 06 06 15 40 F7 is cutoff) with only one value that changes per prameter (the "15" defines the parameter the "40" its value). Patch dump strings will be much longer obviously.tunedLow wrote:I thought sysex was variable length?Altitude wrote: The sysex is about as simple as it gets (very short string, one variable per control)
a xmas present: Here is a Cubase Device Panel for the M1000
http://no-ho.com/m1kpanel.zip
This is not mine, it is made by Cykong, all credit goes to him
http://www.cykong.com/CubaseSX/SXpanels.htm
- xpander
thanks for this post... i'll slap together a M1000 template for the novation ReMOTE, too.Altitude wrote:Sysex strings can be but on the m1000 they very short (i.e. F0 10 06 06 15 40 F7 is cutoff) with only one value that changes per prameter (the "15" defines the parameter the "40" its value). Patch dump strings will be much longer obviously.tunedLow wrote:I thought sysex was variable length?Altitude wrote: The sysex is about as simple as it gets (very short string, one variable per control)
