Roland drum machines triggering korg PolySix Arp.
Can the trigger out from a Roland TR-707, 606 or Boss DR-110 act as the clock source for the arpeggiator on the Korg PolySix?
Since the Mono/Poly uses S-trig on the arp clock, then I would assume that the Polysix does as well.
You will need to make a cable (or mod your machine) to accept v-trig (from Roland machines).
This picture says it all.
http://www.synthesizers.com/moog_trigger-convert.jpg
- Gear: Minimoog model D, Prophet 5 3.3, MultiTrak, Juno-60, 3xPolysix, Trident MkI & MkII, DW8000, DX7IIFD, KX88, and DIY Digisound SSM-based mono.
- OriginalJambo
- Gear: Check my sig
Yeah, you can put whatever you want one the ends of the cable. Just make sure tip goes to tip (signal) and sleeve to sleeve (ground).bionary wrote:Is it possible to make the cable shown in the above link with 1/4 inch on one end and 1/8 inch on the other? The PolySix doesn't use the Jones connector.
