Future Retro Revolution Battery
Postby voltageHead » Mon Mar 10, 2008 12:53 am
I have owned a Revolution for about a year and a half.Thats about the battery life on the ver 1s.
I went to the future retro web site for info on replacing the battery and they recomended to put in a battery holder so you would not have to sodler they battery every year and a half.
So I bought the parts(battery,AA battery holder and double stick tape.
I have my freind open it up and it all ready has a holder in it and it was not taped down!! I had felt some thing loose in there when I moved it around sometimes.
But I had bought this thing new and it came like this.
On the FR web page it said that the batteries are solder in to start with.
I thought that this was strange FR must of made a few of these different.
voltageHead
Postby bakeded » Mon Mar 10, 2008 2:09 am
bakeded
Postby supermel74 » Mon Mar 10, 2008 3:40 am
Seriously though, WTF was FR thinking? Most people who buy a new synth probably don't want to have to bust out the soldering gun a year later to replace the battery.
supermel74
Postby hfinn » Mon Mar 10, 2008 4:33 am
Hence the FRR 2
hfinn
Postby tunedLow » Mon Mar 10, 2008 5:29 am
supermel74 wrote:Seriously though, WTF was FR thinking? Most people who buy a new synth probably don't want to have to bust out the soldering gun a year later to replace the battery.
It's called a mistake. When you design a product from top to bottom you'll make them too.
tunedLow
Gear: Sage XP 4wt 10
Sage TXL 3wt 710
Postby Syn303 » Mon Mar 10, 2008 11:07 am
Apart from the battery issue, im surprised none of you know about the blue jumper, as the Revolution has 2-modes 1) Rev mode and 2) TB-303 mode
Syn303
Gear: Quite a bit...
Band: Syn303
Postby elphcoil » Mon Mar 10, 2008 2:34 pm
hey Syn303, can you elaborate a bit? i've not heard of this blue jumper.
MV-8000, juno-106, vp-330, mks-7, mks-30, mc-202, pro-one, cs-5, dx-7, 770, k2000rs, pulse+, k-station rack, evolver, chroma polaris, filterbank2, drumfire, revolution, mobius, 565T, srv-3030d, rnc-1773, 1591a, vc1-q, 266xl, kaosspad2, and alienator.
elphcoil
Postby Syn303 » Mon Mar 10, 2008 3:45 pm
elphcoil wrote:hey Syn303, can you elaborate a bit? i've not heard of this blue jumper.
If you open up your revolution, and on the underside of the main board i think you will see a blue jumper switch, and if you move the jumper to (i think) it's the left or right (should be two spare prongs showing) move it over to them. This emulates the TB-303 mode (info from Jered)
Syn303
Band: Syn303
Postby Meso » Mon Mar 10, 2008 4:38 pm
voltageHead wrote:I have my freind open it up and it all ready has a holder in it and it was not taped down!!
I replaced the battery of my revo and placed a battery holder for easy future replacing
as mine only had a battery soldered directly to the board.
Do you have any more info on this?
I am just wondering how the 303 mode differs from regular Revo mode as the Revo is basically a 303 clone/emulator.
Meso
Gear: Roland MV-8800, DSI MEK, Novation KS-4, Waldorf µwave XT, FutureRetro Revolution
Postby Syn303 » Mon Mar 10, 2008 6:19 pm
Meso wrote:Do you have any more info on this?
Can't remember exactly what Jered mentioned about changing the jumper and what it does, you'll have to email Jered at F-R and ask him. But opening up your Revolution may void it's warranty, unless it's now out of date!
Syn303
Band: Syn303
Postby Meso » Mon Mar 10, 2008 7:11 pm
I already opened it up to change the battery and place a battery holder,
my battery died after only about 6 months after buying it, it is one of the first ones sn #0019
I guess I'll just e-mail Jered then, thanks anyway.
Meso
Postby voltageHead » Mon Mar 10, 2008 11:22 pm
I never heard about the blue jumper.
That sounds interesting.
voltageHead
Postby Meso » Tue Mar 11, 2008 12:24 pm
Well I just heard back from Jered, this is what he had to say about the jumper settings:
There is a little blue jumper shunt that can be repositioned to connect the
middle pin to the other outside pin of the internal jumper. What this does
is allow the Revolution's amplifier Gate signal to decay over time just as
the original TB303 did. The benefits of the 303 mode is it creates more
varying dynamics between long and short notes, the drawback is that you can
no longer create infinitely sustained notes because the audio level will
eventually decay to nothing.
Thanks,
Jered
Meso
Postby Soundwave » Wed Mar 12, 2008 12:57 am
The Rev by default is set to infinite sustain for (like the Devilfish I believe) which is good for long drone sounds.
The TB303's sustain dies down to emulate the energy lost on a bass guitar string, if you want this setting on the Rev then you have to take the entire casing away from the main base screws and change a blue jumper which you can't miss (tho I'd email Jered before doing so if you still have the guarantee). Personally I'd leave it as it is. 8)
Soundwave
Users browsing this forum: No registered users and 19 guests
