what does the moog realistic concertmate organ sound like?
Postby smallsynth » Tue Mar 25, 2008 9:51 pm
okay, i've been wondering forever: what does this mg-1 thing sound like? can anyone who has one or has heard one compare it to some other organs? does it sound like what?
-geoffrey smallsynth
smallsynth
Gear: jp03, dx21, bass station, k-station, gnat, buzz, cs01-mkii
Band: resterisk
Postby Five » Tue Mar 25, 2008 11:36 pm
it pretty much just sounds like an open square wave
somewhat close to the "string" tabs on most combo organs
Five
Postby Jack Spider » Wed Mar 26, 2008 12:00 am
Jack Spider
Retired Moderator
Retired Moderator
Gear: -
Bit One
Boss DR-220
Boss DR-660
DSI Mono Evolver Keyboard
Korg LP-10
Roland XP-50
Yamaha QX21
Postby smallsynth » Wed Mar 26, 2008 5:35 am
thanks - that's a good clip. does it only sound like a cheezy circus organ?
smallsynth
Band: resterisk
Postby synapsecollapse » Wed Mar 26, 2008 8:46 am
smallsynth wrote:thanks - that's a good clip. does it only sound like a cheezy circus organ?
it also sounds like this:
http://www.youtube.com/watch?v=-s-nOJcw ... re=related
synapsecollapse
Gear: MS20 Mini, Eurorack stuffs, Elektron Machinedrum, Venom, iPad mini, DX7
Postby redchapterjubilee » Wed Mar 26, 2008 2:18 pm
Go to my Virb page at http://www.virb.com/greatunwashedluminaries and listen to "Paths" from my Wield album. The first sound you hear is the MG-1 organ. I kinda liked it.
http://www.soundcloud.com/kellyminnis
redchapterjubilee
Postby Automatic Gainsay » Wed Mar 26, 2008 3:57 pm
First of all, I wouldn't call it an organ. It certainly can sound like an organ, but it does not have organ functionality or intent at all. It is an organ in the same way that any divide-down synthesizer can "sound like an organ." A person specifically looking for an organ would find the divide-down section of the MG-1 as un-organ-like as others seem to find it un-synthesizer-like.
While it utterly lacks organ functionality, it has some very very basic synthesizer functionality. It can be fully affected by the filter and anything that affects the filter... envelope, LFO, etc. In the same way as any paraphonic divide-down synth, it is possible to play it using filter effects in a way that very basically says "synthesizer."
What no one talks about, sadly, is the fact that when you add the monophonic oscillators in the mix with the divide-down section, it sounds even more like a synthesizer than it did. Something about the presence and sound of the monophonic oscillators sort of tricks your ear into thinking you're hearing chords in THAT sound instead of merely a divide-down square wave. Especially when you've got a lot of modulation and portamento, etc. going on.
It is also misleading to separate the polyphonic and monophonic sections. It is perfectly possible to play monophonically in the polyphonic mode... and let me tell you that it adds a lot to the sound of the MG-1. That makes it a THREE OSCILLATOR synth with detune for all three oscillators! It makes a big sound! Especially when you've got the three oscs involved detuned, you've got monophonic osc pitch modulation going, AND portamento. While the portamento and osc modulation does not affect the polyphonic section, the stable pitch of the polyphonic section against the modulation of the two oscs as well as the pitch variances from the portamento make a really impressive sound.
The biggest setback regarding the polyphonic section is that they did not connect the "release" control of the envelope (to the VCA) to the polyphonic section. As a result, there is simply no sustaining the polysection without holding the keys down. Boo! Weirdly, the the attack of the VCA envelope CAN be used with the poly section... but you have to be very deliberate about it.
Ugh. I need to stop typing about it and just MAKE A VIDEO.
Automatic Gainsay
Real name: Marc Doty
Band: Godfrey's Cordial
Postby Synthaholic » Wed Mar 26, 2008 4:13 pm
Automatic Gainsay wrote:The biggest setback regarding the polyphonic section is that they did not connect the "release" control of the envelope (to the VCA) to the polyphonic section. As a result, there is simply no sustaining the polysection without holding the keys down. Boo! Weirdly, the the attack of the VCA envelope CAN be used with the poly section... but you have to be very deliberate about it.
Actually that makes sense from a technological standpoint. The keys act as switches for each note of the divide-down section, so for a note to play the key has to be held down. The keys also trigger the envelope so the attack portion can affect the poly section. But when you release the key, the switch for the note opens, just like when you release the key on an organ. Therefore, the release portion of the envelope has no effect on the poly section. The mono oscillators, of course, go unswitched through the filter and VCA so they can continue to sound through the release.
Adding release to the divide-down poly section would have required a lot more circuitry.
I'd love to own an MG-1 someday. It seems like such a cool little synth.
Synthaholic
Postby ronP » Wed Mar 26, 2008 4:21 pm
redchapterjubilee wrote:Go to my Virb page at http://www.virb.com/greatunwashedluminaries and listen to "Paths" from my Wield album. The first sound you hear is the MG-1 organ. I kinda liked it.
I love that track, RCJ, especially the square wave organ intro, followed by the contained explosions of the snares and that resonant bass sequence that pops in and out beginning around the two-minute mark.
The MG-1 transfixed me one afternoon in early 1983. I had had my CASIO MT-70 for a few months and was ready to move beyond playing sounds . . . I wanted to make sounds. There was an MG-1 at the local Radio Shack, and the clerk let me tweak and play -- "You're a good advertisement," he said. But the folks would not budge so soon after the CASIO. They did help me finance a KORG Polysix a year later, though!
BEHRINGER Xenyx 802; CASIO Casiotone MT-70; KORG Electribe EA-1mkII, microKORG, mini-KP; QUIKLOK T20 T-REX Series X;
ROLAND Micro-CUBE; YAMAHA PSS130, PSS140; ZOOM FS-01, MRS-4B, MRT-3B
Wanted: BOSS DR-110; CASIO CZ-101; YAMAHA CS-01, DX-100
ronP
Gear: BEHRINGER Xenyx 802; CASIO MT-70; KORG EA-1 mkII, MicroKorg, microSTATION, MicroX, Mini-KP, Monotron; ROLAND Micro Cube; ZOOM FS01, MRS-4B, MRT-3B
Band: Keyfish
Postby Automatic Gainsay » Wed Mar 26, 2008 5:01 pm
Synthaholic wrote:Actually that makes sense from a technological standpoint. The keys act as switches for each note of the divide-down section, so for a note to play the key has to be held down. The keys also trigger the envelope so the attack portion can affect the poly section. But when you release the key, the switch for the note opens, just like when you release the key on an organ. Therefore, the release portion of the envelope has no effect on the poly section. The mono oscillators, of course, go unswitched through the filter and VCA so they can continue to sound through the release.
That makes sense! Thanks for the clarification.
As the poly section was added, supposedly, as an afterthought in order to land the Radio Shack deal, it's not surprising that they would cut that corner.
Automatic Gainsay
Postby redchapterjubilee » Wed Mar 26, 2008 5:21 pm
ronP wrote:I love that track, RCJ, especially the square wave organ intro, followed by the contained explosions of the snares and that resonant bass sequence that pops in and out beginning around the two-minute mark.
Thanks! That's one of maybe two tracks I used it on as an organ. More often I'd use it like a suboscillator.
The MG-1 is a neat little synthesizer. I think it is a fine gateway into subtractive synthesis. I'd love to find one again for what I paid for the one I used to have, but I think the days of the $250 MG-1 are completely over.
redchapterjubilee
Postby smallsynth » Wed Mar 26, 2008 6:48 pm
thanks for the link rcj. your "organ" tone sounded pretty good -- at least you made it sound good in the context of that track.
ag, ha! sometimes you get verbose... but it's just about always worthwhile. i was noticing in the clips how it sounded so synthlike with the mono and poly mixed. what you wrote resonated with me. it doesn't sound too far off from a paia oz to me. i wonder if you ran it through some pedals if you could get some dirt or more interesting organ like sounds out of it...
smallsynth
Band: resterisk
Postby Tedd » Fri Mar 28, 2008 1:12 am
smallsynth wrote: i wonder if you ran it through some pedals if you could get some dirt or more interesting organ like sounds out of it...
Yes, you can use the headphone jack as an audio output.
And this is some MG-1 work featured over on Matrix Synth...
http://www.youtube.com/watch?v=x8BSMr4odWE
Tedd
Postby smallsynth » Fri Mar 28, 2008 5:45 pm
see now, that's pretty good. a little dirty. that's a workable approach. it's piked my interest. needed a little vibrato, though.
smallsynth
Band: resterisk
Postby Tyler2000 » Fri Mar 28, 2008 7:31 pm
Big open square as said before. I rather like it's limitations for a few reasons. 1 is playing chords on the left and a lead on the right. Another is pretending I have two VCAENVs by setting a long release on the mono oscs so that when I hit a note only part of it has a long realeaseeaseea. I think it's a f**k awesome synthesizer. Also the retrig and continuous modes are often overlooked, but I think they ALOT to an already quirky synth.
so what do I put down here now?
Tyler2000
Gear: HS-60, MG-1, CS-5, ESQ-1, CZ-101, DR-110, MR-10, MDP-40, EA-1, ER-1, ES-1, Trixer, SDS-9, Califorian 365, toys, guitars, ukes, etc.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 1 guest
