If anyone is interested, I can do a similar demo with the other analog sounds similar to what I did with the kick.
Speak up!
-Jim
...this @£*%@$!! Violent Beast is Destroying My Studio!!!!
- shaft9000
- Real name: Dave
- Gear: Whips chains waxes oils dildos DMT TNT the LHC, and a black rubber duckie
- Band: moneymoneymoney
interested? I'M RIVETED
- Gear: Ultranova, Minibrute, Microbrute, Spark, microKORG, microX,
Sic demo pix! I'd ditch my xbase and maybe a few other things to get an 888! I wouldn't mind having a two synth and one bad-a*s drum machine set up.pix wrote:here's some patterns of the 888 in action.
I'm using separate channels for each part.
For these loops there's a filter and a delay send for each sampler part, sometimes the hats also go to the delay and there's a barely noticeable reverb on the snare.
No comps or EQs on the channels. Just a comp in the master bus. Only ableton fx were used.
These were 30 second mixes so it can be made a lot better with more time.
http://pixmusic.net/audio/888loops.mp3
enjoy!
