If you could have only ONE analog synth...
- Synthaholic
- Expert Member
- Gear: Motif XS6, TX802, D-550, A6
... what would it be?
One catch though, it has to be less expensive than a Jupiter-8. So, let's say, $3k max.
Me... probably an Andromeda, or MKS-80, or Jupiter-6.
You?
You?
- Johnny Lenin
- Expert Member
- Gear: JX8P | AX60 | Little Phatty Stage II | DW8000 | Vox Jag | Fantom X6 | Juno-G | P-Bass | AS-120 | Double Jet
I've only played the Prophet 08 in the shop, but I've liked what I've heard. I like the idea of a modern analog polysynth. Haven't played the Andromeda, so I can't say if I'd like it.
A Perfect Vacuum: http://www.myspace.com/aperfectvacuum
The Plateau Phase: http://www.myspace.com/plateauphase
- Jack Spider
- Retired Moderator
- Gear: -
Bit One
Boss DR-220
Boss DR-660
DSI Mono Evolver Keyboard
Korg LP-10
Roland XP-50
Yamaha QX21 - Location: Old Blighty
If I could only have one, I'd go for a CS-80, as there's no chance I could buy one!
- Senior Member
- Real name: Eric
Unfortunately, there isn't one single analog synth that could make up for the absence of the rest.
If I had to replace my JX-10 with something better, I'd take an Oberheim OB8. It and the Voyager would work so well together. But then, I wouldn't want to have one without the other. That's the closest I'd get to the querry of this thread.
The greatest thing we ever have is the will to survive.
Rest in peace, Dr. Robert Moog.
http://www.ericbenjamingordon.com
http://cdbaby.com/cd/ebgordon
http://www.myspace.com/ericbenjamingordon
- No Longer Registered
- Senior Member
- Real name: Eric
Ha ha ha, very good, clubbedtodeath. Every synthesist's dream.
Re: If you could have only ONE analog synth...
What if I already own a JP8? My logic says if I keep something I already own, then cost isn't a factor. With that in mind, I say JP8.Synthaholic wrote:One catch though, it has to be less expensive than a Jupiter-8. So, let's say, $3k max.
Otherwise, I guess an Xpander would be less than $3k and versatile/intuitive enough to only keep one.
--Solderman no more.
