Knobs on Yamaha CS2x ?
Postby Jexus » Sat Nov 29, 2008 4:48 pm
Is there any way to take the knobs off the panel, or are they glued there forever or something ?
I don't know how those dickheads managed to immobilise it during shipping, but the volume knob will not turn.
And I can't remove the chipboard if I don't remove the knobs first.
Jexus
Re: Knobs on Yamaha CS2x ?
Postby Maschinengeist » Sat Nov 29, 2008 7:15 pm
I do like this:
1) Piece of clothing (to avoir marking the knob & the synth)
2) A flathead screwdrive (a tiny one but robust too)
3) a pair slip joint pliers
Put some clothing aroung the head of the screwdriver and GENTLY slip the headof the screwdrive under the knob
Put some cloth around the knob to avoid denting it
Gently worh your way under the knob from left to right until you feel the pot while pulling wih the pliers.
The piece of cloth is,as you can see, really important. And the trick is to go gently to avoid breaking the knob. Yeah, it'sreally time-consuming but it always worked for me.
Hope that helps
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Postby Jexus » Sun Nov 30, 2008 1:38 pm
Maschinengeist wrote:I do like this:
Hope that helps
Yeah, I have my own tricky way of doing it too. I use curved tweezers to sort of... lift the knob up. And it always worked but not this time. But have you owned a CS2x ? Are you positive that they CAN be taken off ?
Jexus
Postby Yekuku » Sun Nov 30, 2008 9:28 pm
I own a cs2x and I can confirm that the knobs can be very easily pulled off.
Actually, so easily that it could be a production fault.
My guess is that the previous owner had it glued in order to avoid accidental removal.
It is all about sharing...
Yekuku
Postby Maschinengeist » Mon Dec 01, 2008 8:29 am
I never owned a CS2x but worked on them only.
Why would I bullshit you? They usuall come off like a charm. But it happenf that they won't come off easily for whatevever reason.
Asusual, just trying to help. Don't believe me if you want...
MuzikElektronix.com
Help? See TechZone
Parts? email!
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Postby rhino » Mon Dec 01, 2008 4:03 pm
maybe owned once by the same guy as my CZ-1: couple of broken keys ""FIXED"" with about a pint of contact (rubber??) cement on ,in, around, over,under the bad keys and three or four on either side....dripped down on the contacts and circut board.....jeez ! what a mess!
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby Jexus » Tue Dec 02, 2008 6:35 pm
Maschinengeist wrote:I never owned a CS2x but worked on them only.
Thanks for the advice, but the way you presented your insight suggested just the general way you work with all synths, so I just wanted to make sure you know how the CS2x behaves. Now I know MY cs2x is not in its original condition.
Jexus
