Synth outputs... balanced or unbalanced?
READ: Please Read the Rules of Sound Production.
- Gear: PEK, Voyager, JP-8080, Sirius, Radias, Lead 2, X-Station25, KS-Rack, Z1, MPC4000
Do synths pretty much all have unbalanced outputs? I am planning a cable purchase along with a audio interface that supports balanced and want to make sure I get the right thing.
PS: my list of synths is on my avatar.
Re: Synth outputs... balanced or unbalanced?
Most synths are unbalanced. You can use balanced cables with no issues.
- novielo
- Moderator
- Gear: in order of appearence:
sh2000 s612 nord modular mpc1000 kp3 ms-something cp-251 gameboy s6000 and other crappy stuff - Band: one-man band
- Location: by the river, st-jerome, quebec, canada, north america
do you have access to one balanced cable to try it out? my sh-2000 will refuse to work with a balanced cable pluged in. all my other newer synth do work tough.
- Stab Frenzy
- Moderator
That's not correct, there are a number of issues with using unbalanced outputs with balanced cables to balanced inputs. You're much better off using unbalanced cables to balanced inputs, and you won't notice and difference in signal/noise ratios at line level.Alex Hamilton wrote:Most synths are unbalanced. You can use balanced cables with no issues.
- Gear: K2500RS + KDFX, K2600R, 2 x DMTi, KSP8, Capybara 320, DSI Mono Evolver Kbd, DeepBase9, Powercore Firewire + Virus, Yamaha TX81z & 03d
As Stab Frenzy said, best to test first.
e.g.
Kurzweil K2600R has balanced aux outputs
Kurzweil K2500R has unbalanced aux outputs (but with TRS jacks to provide inserts for each only if a TRS cable is used)
The majority of (ahem) "cheaper" synths tend to have unbalanced 1/4" jacks but some break the norm.
e.g.
Sorry, you're right, I was thinking the other way round. God knows why, the question was obvious.Stab Frenzy wrote:That's not correct, there are a number of issues with using unbalanced outputs with balanced cables to balanced inputs. You're much better off using unbalanced cables to balanced inputs, and you won't notice and difference in signal/noise ratios at line level.
- Mr Knesh
- Junior Member
- Real name: Roland
- Gear: DP/4+ because in order to dive in deep, you have to DP.
The only synth that I have ever seen that had balanced outs on it was the Alesis Nano-Piano.
The only synths I can think of with balanced outs are the Moog Voyager Rack, Roland Fantom, Access Virus TI Polar, and Kurzweil stuff ..The Jupiter 6 and 8 have XLR balanced outs..Mr Knesh wrote:The only synth that I have ever seen that had balanced outs on it was the Alesis Nano-Piano.
Synthi: DSI Polyevolver, DSI Prophet 08, Moog Source, Moog Voyager, Roland Fantom X8, Generalmusic S2 and SK88, Yamaha RM50, MFB Kult
Future: Macbeth X-Factor
Tks folks! That's pretty much what I thought, that unless I have a high-end workstation, I am very unlikely to have balanced outs.
- OriginalJambo
- Gear: Check my sig
There's generally no real need for synths to have balanced outputs as, unlike microphones, you are unlikely to be using great lengths of cable. I third the notion that unbalanced cables would be best, unless of course you are running a lot of cable in which case a DI box might be the ideal solution.
- clusterchord
- Real name: Tomislav
- Band: Nimbus Dei
balanced outputs are rare on synth. of ones i use, i found em on Jupiter8, MKS80 and Emu EOS samplers.
most of the time its not necesarry, but i sometimes use it if its there. for example, JP8 sounds slightly better going balanced direct into balanced line input on fireface, then using its unbalanced jack output. so i record direct balanced, and use the unbal out to send it to a BBD delay etc.
as for choice of audio interface, most that have balanced inputs are combo and auto-switching... ie.e they support unbalanced input as well, tho its 6dB quieter, so these cards usually offer some i/o level control panel. choice of +4 or -10 operation etc.
one situation that might pose a problem is if u plan to use an some older outboard that hasn't auto switching input but strictly balanced i/o, you cannot input an unbal. synth there straight. it needs some conversion first - usually u would go to a preamps hi-z input. it adapts impedance, fixes level and balances the signal.
for example lexicon300 and panasonic dat was like that.
- iProg
- Expert Member
- Real name: Carl
- Gear: Prophet-5, Korg PolySix, Roland D-50, JV-1080
- Band: ArtWithHeart
Balanced/Unbalanced? What is the difference? *completely clueless* :-k
- Stab Frenzy
- Moderator
http://tinyurl.com/d6n7a6iProg wrote:Balanced/Unbalanced? What is the difference? *completely clueless* :-k
- Untouchable_888
- Junior Member
- Real name: Nightshade
- Gear: Cheetah ms6
Moog Mother-32
Roland JP-08
Novation Circuit
Korg Volca Sample
bass guitar - Band: Heart of Thorns
So using 1/4" TRS to XLR cables on my Minibrute and Cheetah ms6 is a bad idea? I have them going into the front of my Scarlet 18i8 via the afore mentioned cables.Stab Frenzy wrote:That's not correct, there are a number of issues with using unbalanced outputs with balanced cables to balanced inputs. You're much better off using unbalanced cables to balanced inputs, and you won't notice and difference in signal/noise ratios at line level.Alex Hamilton wrote:Most synths are unbalanced. You can use balanced cables with no issues.
I came across this thread because I was trying to figure out if the Output jack on the JP-08 is balanced or unbalanced. I currently and using an 1/8" TS cable with a 1/8 to 1/4 inch adapter on the end. (Same with my Volca Keys except the cable itself is an 1/8 to 1/4 inch TS/mono cable.) I can run a TS cable from all four of my synths if that's what I should be doing.
I just thought that the XLR would give me better quality..
A.D.I.D.A.S.
[All Day I Dream About Synths]
~NOVATION IMPULSE 49 -> Cheetah ms6, Roland JP-08, Arturia Minibrute, Kong Volca Keys, bass guitar, <-/-> M-Audio MIDIman 2x4 -> Focusrite Scarlett 18i8 etc.
- Stab Frenzy
- Moderator
No a TRS -> XLR connection will give you worse quality for the following reasons:
- The XLR inputs are low impedance mic inputs. The synth's outputs expect a high impedance line input and can have difficulties supplying enough current to a low impedance input, particularly cheap, low power units like the JP-08 and Volca.
- The ring -> cold connection will be floating which means it'll be able to pick up extra noise rather than performing its job of reducing noise.
What you need are unbalanced leads going into the line inputs of your interface.
