Korg Maxikorg/800DV keyboard problem
Postby Astroman » Tue May 19, 2009 8:30 pm
Hi,
I just got Maxikorg and it seems to have a problem with keys. Key C2 splits the keyboard and so every "lower" part´s notes are same up from C2 and accordingly every "upper" part´s notes are same above C2. Also lower VCO doesn´t sound exactly same as upper one. :(
Does anybody have been same kind problems?
Astroman
Re: Korg Maxikorg/800DV keyboard problem
Postby schmidtc » Tue May 19, 2009 8:59 pm
I've got two maxi-korgs and the upper and lower sections on each sound slightly different. I haven't tried tracing it to the vco's so I'm not sure where in the signal path the change occurs. Does the problem with the keys occur in all 4 transpose modes?
schmidtc
Postby Astroman » Wed May 20, 2009 5:15 pm
It´s same with all key transpose combinations.
Astroman
Postby mmp » Sun Apr 27, 2014 1:38 pm
A very old thread, but for those searching for the solution, this is a blown transistor at the stuck note position on the keyboard circuit.
Michael McInnis Productions
www.mm-pro.com
mmp
Real name: Michael McInnis
Gear: VS VL-1 Varios VoyagerRME MinimoogD CS60 SY-2 Kronos M3X MW1 2600 PS3100 DV-800 Z1 Chroma XT Blofeld k5K PolyMoog Avatar MS20 PE-1000 P6 OB6 m4000d
Band: Iberquez
Users browsing this forum: Bing [Bot] and 6 guests
