yamaha cs10 problems, please help
Postby dubstep » Fri Aug 07, 2009 7:28 pm
So my yamaha cs10 is making a continuous sound even when both oscillators and the master volume are turned all the way down. The sound responds to all the vco parameters as well as the pitch bend, glide and vca lfo. The sound goes away after I turn the console off and on again however as soon as I press a key it comes back. Any help would be greatly appreciated.
Thanks
dubstep
Re: yamaha cs10 problems, please help
Postby pflosi » Fri Aug 07, 2009 8:06 pm
seems like the vca could use some calibration
Postby garranimal » Fri Aug 07, 2009 9:20 pm
That's weird the master volume has no effect. Maybe the master volume needs cleaning or replaced.
You haven't mentioned trying these things yet. Make sure in the VCA the Hold/EG switch is set to EG, as it appears the sounds may not passing thru the Envelope Generator. Make sure the Envelope Generator is set to 'Normal' and not 'TIMEx5' as you may have an exceeding long release time.
garranimal
Postby nadafarms » Fri Aug 07, 2009 9:21 pm
dude are you sure you don't have the vca gain all the way up? it's on the far top right on the cs synths and will make your synth continually drone if it's up at all it should be all the way down.
it's been a long time since I've had a cs but this happened to me many times...
for sale/trade: EML-101
nadafarms
Postby HideawayStudio » Fri Aug 07, 2009 9:43 pm
nadafarms wrote:dude are you sure you don't have the vca gain all the way up? it's on the far top right on the cs synths and will make your synth continually drone if it's up at all it should be all the way down.
Spot on - I was thinking the same thing as nadafarms. I had a CS-5 for many years and this feature forever caught me out. It was over on the top right on the CS-5 too. I'll bet there is nothing wrong with your CS-10 - these things are indestructible!
HideawayStudio
Real name: Dan Wilson
Band: Shortwave
Postby nathanscribe » Fri Aug 07, 2009 11:46 pm
Doesn't the CS-10 have a separate volume control though..?
nathanscribe
Postby HideawayStudio » Sun Aug 09, 2009 5:25 pm
nathanscribe wrote:Doesn't the CS-10 have a separate volume control though..?
Yes it does - as does the CS-5 - the problem is the weird VCA gain control is confusing at best. If it's wound up too high it has the effect of preventing the envelope shutting off the VCA hence the note sounding for ever. There are times where I guess this might be useful - eg. passing an external input through the filter but most of the time it's annoying.
Knowing just how reliable these beasts are I really doubt it's any more than this.
HideawayStudio
Band: Shortwave
Postby dubstep » Sun Aug 09, 2009 9:17 pm
thanks for all the replies unfortunately I don't think its the vca gain control because the cs 10 doesn't have one.
Here is a pic:
http://www.proun.net/img/yamaha/yamaha_cs10.jpg
The sound is still affected by the keyboard in that I can play melodies and the sound reacts just as if i was normally playing the synth with the vca hold switch on however, in the mixer section everything is turned down and the volume is all the way down. Could it be something to do with with the trigger as the sound only comes on after a key is hit?
any ideas are appreciated although I'm slowly coming to the realization that I might need to take a trip to the synth technician.
dubstep
Postby HideawayStudio » Mon Aug 10, 2009 10:13 am
dubstep wrote:thanks for all the replies unfortunately I don't think its the vca gain control because the cs 10 doesn't have one.
Here is a pic:
Yes - apologies about this - I used to own a CS5 and always thought what functionality the CS10 shared was the same - obviously some details are different.
That said - it could still be something silly.
HideawayStudio
Band: Shortwave
