SY77 hz
Chas
SY77 hz
Post by Chas » Fri Nov 06, 2009 1:20 pm
Just need to know what the SY77 hz rating is. I am guessing it is 60hz?
I need to know this so I can buy the appropriate step down transformer to run my 120V SY77 here in Australia.
I google searched this to death but could not find the bloody answer anywhere!
Chas :)
b3groover
Real name: Jim
Band: THEO
Re: SY77 hz
Post by b3groover » Fri Nov 06, 2009 4:11 pm
If it's coming from the USA, then yes. 120v, 60Hz.
Chas
Re: SY77 hz
Post by Chas » Sat Nov 07, 2009 9:28 am
Ok thanks very much.
Also, I need to know how many watts is the SY77.
Not sure which of these to buy as I will also need to run some Mackie HR864's on 110v: http://www.tortech.com.au/stepdown.html
crystalmsc
Band: Crystaline
Re: SY77 hz
Post by crystalmsc » Sat Nov 07, 2009 10:50 am
Chas wrote:Also, I need to know how many watts is the SY77.
The specification from Yamaha's page said the power consumption is 28 Watts.
Kaossilatron - Voicillator
b3groover
Real name: Jim
Band: THEO
Re: SY77 hz
Post by b3groover » Sat Nov 07, 2009 6:56 pm
According to the back of my HR864's, they pull 150w each. Looks like you'll need the 500w stepdown transformer.
Chas
Re: SY77 hz
Post by Chas » Sun Nov 08, 2009 7:54 am
Thanks for checking that out for me B3groover. I just found a stats page for the Mackies saying that their low freq "Burst power output" is 350 watts. Do I have to make allowances for this "burst power"?
http://www.mackie.com/products/hr824/specs.html
Sorry for the newbie question, I hope you don't mind.
crystalmsc, thanks. Wow that seems quite low compared to other gear.
b3groover
Real name: Jim
Band: THEO
Re: SY77 hz
Post by b3groover » Sun Nov 08, 2009 9:01 am
It probably depends on how hard you plan on pushing the speakers. The amps in the speakers are not class A, but probably class F or even G or H. They'll only pull as much current as they need. So if you're not blasting them, you'll be fine.
That said, I'd rather have more than enough power rather than not enough power, you know?
Chas
Re: SY77 hz
Post by Chas » Sun Nov 08, 2009 1:21 pm
Cheers mate. Yea I'm not the blast type. The 500W transformer should be fine for me.
