sh101 internal pots
sh101 internal pots
what do the internal pots do inside the sh101, and which ones are safe to tweek without adjusting the tuning and timing?
- Syn303
- Expert Member
- Gear: Quite a bit...
- Band: Syn303
Re: sh101 internal pots
"Ne Touche Pas" - Don't Touch, or you won't have a 101 that sounds like a 101 anymore, only adjust if you know what they exactly do and that you can put them back to the correct factory adjustment settings. Refer to the Service notes only.
Power Supply - VR1 +5V (D/A Width)
D/A Conveter - VR2: D/A Tune / VR3: D/A Linear / VR5: Range Width
VCO - VR4:Pulse Width / VR6: VCO Width / VR7: VCO Tune
VCF - VR8: VCF Width
- Maschinengeist
- Real name: Steph. J
- Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff - Band: Cybernetik
I second Syn303
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
MuzikElektronix.com
Help? See TechZone
Parts? email!
- snod_donkey
- Junior Member
- Gear: Moog Minimoog - SCI Pro-One - Roland Sh-101 - Yamaha XS6 - Oberheim OB-Xa - Roland TD8 - Evans super Echo Tape Loop - Memeory Man Deluxe
Dont do anything unless you have to... and then only do it if you have all the correct test equipment and the set up notes. Its not an easy job
ive descided to make some music instead!
