Roland JX3P buttons 9-16 are failing
Re: Roland JX3P buttons 9-16 are failing
Postby EmptySet » Thu Dec 02, 2010 10:34 am
cornutt wrote:Are you guys sure it's the switches themselves? This sounds to me like a scanning problem. Say, a ribbon cable going to the panel board that isn't making good contact.
Yes, it's the switches. If I move a reasonably OK one to a position where there is a crummy one, the good switch continues working just fine (and the crummy still doesn't work). The switches are messed up in some fashion. Some work fine. Some don't work at all. And some are in between (e.g. might work if I lean them).
EmptySet
Postby Ry-Fi » Thu Dec 02, 2010 11:16 am
Beats me! :lol: Is it corrosion? Dust/debris (is that even possible?)? Moisture? I really don't know. I just know it worked, in this particular case...
Ry-Fi
Gear: Ion, MKS-30, MKS-50, SQ-1+ 32-voice, TX81Z
Postby cornutt » Fri Dec 03, 2010 3:37 am
Interesting. That's weird that one whole row of switches would fail like that. Maybe someone spilled something on it at some time in the past.
cornutt
Gear: 6th
Postby EmptySet » Sat Dec 04, 2010 9:19 am
cornutt wrote:Interesting. That's weird that one whole row of switches would fail like that. Maybe someone spilled something on it at some time in the past.
Well, one whole row of switches hasn't failed. They just almost all suck in one fashion or another. Like they're old or something. Some work fine. Some require a couple tries. Some are just bunk. And this is BOTH rows of switches. I really think that their switch parts for this model are crummy. Others have stated that they've had similar problems. The synth works perfectly otherwise.
On a related note, my Juno 106 had some lousy button switches in a similar fashion. But it was far easier to find replacements. I yanked them all and replace with new ones (sliders too). It's a dream… works like new.
EmptySet
Postby precarity » Thu Jun 30, 2011 7:52 pm
Bumping an older thread since a lot of the info pertains:
Anyone figure out any sources for JX3P buttons / switches? I'm sprucing up a friend's JX3P, which apparently suffered a spill at some point, leaving about 4 of the push buttons wonky (some trigger intermittently, one doesn't even "click" anymore). I checked technology transplant and syntaur and came up empty. There's 4 on eBay in the UK, but they're pulls the guy wants £7/ea for — this is a "whenever it can get done" fix, and I think I can do better than that.
I don't suppose someone has another source for NOS switches at $3.50 a pop, eh?
precarity
Postby rhino » Thu Nov 08, 2012 6:07 pm
UPDATE ! UPDATE ! WILL ROBINSON!
Just started repairs on a JX3-p. Patch buttons 9-16 were dead. Checked signals at the ICs and they looked OK. Switches checked ok.
Finaly got down to continuity checks on the traces... OPENS !!!!!
CHECK the TRACES at the LOWER RIGHT corner of the button board. Look for a crack starting at the mounting-screw hole and extending thru the curved traces near it.
The bender also went only "up". SAME thing on the left lower corner, right near the screw hole.
Must be flexing of the PC board from falling on the front panel. having another synth dropped on it, or maybe just rough use.
Fixed a total of 8 traces. Bingo! Image Image
Pix soon.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Previous
