physical MIDI cable specs
- Expert Member
- Gear: Octatrack
Bass Station 2 - Band: TBA
OK so I am making a 'double adaptor' midi plug because I have 2 devices with only a midi IN port on them... I know it is not 'recommended' but it works when I dont need to send different data to them and the distance is less than 20cm.
Anyhow after I spent all the time soldering up the wires to the 5 pins + ground for each 5-pin DIN plug I remembered something..
I only have to use 2 pins + the ground when I send MIDI out of my Arduino... it works fine.
But then I cut open a dead midi cable I had, and it has all 5 lines.
So that leaves me with 2 questions:
1) Do I only have to use the 2 pins + ground to make my own midi cables? Or do some devices send midi down all 5 cables therefore need them?
1) If I only need 2 + ground, then why the h**l did they choose FIVE pin din sockets to be the midi standard? expandability? lack of foresight?
- madtheory
- Real name: Tomas Mulcahy
Re: physical MIDI cable specs
Two pins and the ground is the correct wiring for a MIDI cable, anything else can cause problems. A lot of MIDI cables are not actually MIDI cables at all, but DIN audio cables rebadged.
All midi I'm aware of only uses 3 of the 5 pins.
- meatballfulton
- Moderator
- Gear: Logic Pro X
The actual cabling spec indicates that pins 1 and 3 are never connected.
Why did they choose 5 pins? At the time of MIDI 1.0 it was thought that future extension of the spec would make use of the extra pins. This has not happened yet.
- Synthaholic
- Expert Member
- Gear: Motif XS6, TX802, D-550, A6
Another interesting tidbit about the 5-pin DIN connectors used for MIDI: they are the same connectors that the original IBM PC and PC/AT used for the keyboard. Many "clone" PCs even into the mid 90s used this same "AT" keyboard connector. Why is this relevant? Well, one time years ago I needed a longer MIDI cable for something, and I was able to use an AT keyboard extension cable to do the trick.
- Expert Member
- Gear: Octatrack
thanks guys!
Funny how such a simple thing can have quite a complicated background.
madtheory wrote:Two pins and the ground is the correct wiring for a MIDI cable, anything else can cause problems. A lot of MIDI cables are not actually MIDI cables at all, but DIN audio cables rebadged.
Also worth mentioning that the ground is only connected on the midi output, never on a midi input (It's just for shielding so its open on one end)
- cornutt
- Moderator
- Gear: 6th
Also, DIN sync a la the Roland X0X drum boxes use the two pins that MIDI doesn't use. So some MIDI cables are also sold as DIN sync cables.madtheory wrote:Two pins and the ground is the correct wiring for a MIDI cable, anything else can cause problems. A lot of MIDI cables are not actually MIDI cables at all, but DIN audio cables rebadged.
- Shreddie
- Junior Member
- Gear: Alesis Andromeda, Fusion 8HD: ART SGX Nightbass SE: Kawai K5000s: Yamaha A3000 V2, EX7, FS1R, PSS-480 (Don't laugh, it rocks!) and 4 planks.
If you're planning on making your own midi cables, just use 2 core mic cable... It's of a higher standard than most off the shelf midi cable so is useable for surprisingly long runs, I've read that upto 70m is possible.
- Hybrid88
- Gear: V-Synth, and other stuff...
Personally I'd rather get something like this for splitting purposes;
http://cgi.ebay.com.au/Touchprone-1x3-M ... 2554d7632b
- Expert Member
- Gear: Octatrack
wow.. There is no way I would ever pay $55 for that thing.. or even $25 for that matter. That box doesn't even seem to be powered (meaning it's doing exactly the same thing my device is.. but costs 10x as much)
- madtheory
Actually it does claim to be powered, it draws power from the MIDI line. That's entirely possible, there's 5V there to play with. In fact it's not possible to split the MIDI signal 3 ways without power.
Your passive splitter will work, but not with every piece of gear.
- Hybrid88
Fair enough, it's really not much to outlay though for what your getting. Difference is the $55 one is designed to work, plug and go. Whereas your solution is a bodge solution, that's not to critisise sure it might work sometimes, but I cant see it being very reliable... YMMV tho
cartesia wrote:wow.. There is no way I would ever pay $55 for that thing.. or even $25 for that matter. That box doesn't even seem to be powered (meaning it's doing exactly the same thing my device is.. but costs 10x as much)
- Expert Member
- Gear: Octatrack
there may be a few old devices it wont work with, but it's not gonna be like a half the time it works, half the time it doesnt thing, so yeah.. for me, it is perfect (more than 1 device that only has a midi IN port)
