What is this effect called?
m83lover
Post by m83lover » Tue Jan 11, 2011 4:04 am
when a sound signal at any speed is thrown from left to right
n00b question srry ;(
Sir Nose
Real name: Bob
Re: What is this effect called?
Post by Sir Nose » Tue Jan 11, 2011 4:16 am
panning
or
maybe a ping-pong effect
Funkadelic wrote: nothing is good unless you play with it
all that is good is nasty
ninja6485
Band: Subliminal Sea
Post by ninja6485 » Tue Jan 11, 2011 5:10 am
the korg radias has an effect called rotary, which wirls the sound arround from left to right as though it were spinning arround you, or like a constant left to right wobble.
Zamise
Gear: Rollhand P00
Band: Quantum-Source
Post by Zamise » Tue Jan 11, 2011 10:22 am
An Auto Pan effect, or some Delay effects that can have dif left and right times can sort of do too, or one of my favs which is a Slice effect with different pan types.
Synthaholic
Post by Synthaholic » Tue Jan 11, 2011 3:10 pm
It depends on the effect...
If the sound repeats like an echo, going left, right, left right until it fades away, that's a ping-pong delay (example: tambourine sound in "Drive" by The Cars).
If it pans smoothly left to right and back (like a lot of EP/vibraphone sounds in the 70s and 80s), that is an auto-pan effect (example: "Babe" by Styx).
If there's some pitch shifting/phasing going on along with the panning (commonly used on organ sounds), that's a rotary speaker effect, also called a Leslie effect since it emulates the Leslie rotary speaker systems often used on Hammond and other organs. (many examples, Steppenwolf's "Born To Be Wild" comes readily to mind)
cornutt
Gear: 6th
Post by cornutt » Tue Jan 11, 2011 4:26 pm
Good points. One thing to add is that a rotary speaker might or might not have any left-right motion, depending on how they miked it up when it was recorded.
gridsleep
Real name: Kurt
Gear: Das Vorlagengehirn
Band: Big Steam Horse
Post by gridsleep » Sat Jan 15, 2011 4:20 am
Synthaholic wrote:...(many examples, Steppenwolf's "Born To Be Wild" comes readily to mind)
Also the beginning of Pink Floyd's Us And Them.
The piano intro to "Echoes" was also run through a Leslie.
Nymph, in thy orisons be all my synths remembered.
