Director-S for the Roland S-330?
Postby mingle » Mon May 02, 2011 4:03 am
Hi Guys,
I'm currently awaiting the arrival of my first ever rack/module - a nice Roland S-330... :-)
Up until now, I've only ever felt comfortable with keyboards - I used to have an S-50 and loved it!
I've read a bit about the excellent Director-S software and have heard rumblings about there being a version out there that doesn't require the original program dongle.
Does anyone know where I'd be able to locate a copy, as I reckon it'd be much better than using an outboard sequencer.
Cheers,
Mike.
mingle
Re: Director-S for the Roland S-330?
Postby Silverfish » Mon May 02, 2011 7:13 am
I've got a disk image. Check your inbox for a PM shortly. :D
Silverfish
Real name: Tyler
Band: Silverfish
Postby mingle » Mon May 02, 2011 10:39 am
Tyler, you're a legend... Now all I need is an S-330 to use it on :lol:
Cheers,
Mike.
mingle
Postby dimxl » Tue Jan 21, 2014 10:11 pm
Hello,
I am in similar situation - awaiting the arrival of Roland S-330.
I like to use onboar sequencer and I need to find copy of Director-S software that doesn't require the original program dongle.
Could anybody help me to find it?
Thanks in advance,
Dmitriy
dimxl
Postby D-Collector » Wed Jan 22, 2014 11:26 am
dimxl wrote:I like to use onboar sequencer and I need to find copy of Director-S software that doesn't require the original program dongle.
Thanks in advance,
Dmitriy
No problemo friend.
I uploaded a RAR archive for you with everything you need, disk images, SDisk for windows, manuals:
http://www55.zippyshare.com/v/77936744/file.html
If you only need the (dongle-free) Director-S disk image, then use this link:
http://www31.zippyshare.com/v/41308364/file.html
:thumbright:
D-Collector
Postby dimxl » Wed Jan 22, 2014 2:45 pm
D-Collector, thanks for you great help!
Could you explain, is "Roland Utility Disk 1.03.OUT" system disk or not?
Also I see that you old link to "director-s" video does not work. I have not found any video or tutorial about this sequencer.
Dmitriy
dimxl
Postby D-Collector » Wed Jan 22, 2014 5:06 pm
You're welcome!
Yes, it is the system disk, and must be booted. Alternatively if you make a disk with your favorite sounds/patches the system can copy the OS onto that disk, so you can boot your favorite sound disk.
If you wish you can also boot with the sequencer disk, but if you want to use onboard sounds you must load in the utility disk afterwards. If you want to use the S-330 as sequencer only, then the Director-S disk will do.
No, unfortunately I no longer have those videos up, but there wasn't much help in them anyway.
Luckily the sequencer is very easy to use.
D-Collector
Postby nathanscribe » Wed Jan 22, 2014 7:20 pm
It's a long time since I used it, but I remember SDISK being pretty straightforward to use (I used it to write Roland library disks for my W-30, on a DOS computer). You'll need 720kB floppies, and you'll need to format them correctly, if the S-330 works the same as the W-30 in that respect.
Meanwhile: http://www.sgroup.ca
nathanscribe
Postby Fatbenelton » Fri Jan 24, 2014 1:27 pm
The Roland Sampler Users Group is an old but valuable resource that is well worth browsing….clunky site but still maintained and active!
Also, I think there were several versions of Director-S - I seem to recall different samplers required different versions or something like that - i.e. Director S S330 edition or s550 edition etc
Jonny Jones
Fatbenelton
Gear: Moog Source, MS20, Jupiter 4, Trident, Prophet VS, Roland SH2, D550, KS5, SY35, GEM S2, Crumar Performer, RX5, Roland CR8000, Korg KR55. Minipops 7
Postby Fatbenelton » Fri Jan 24, 2014 1:50 pm
Just had a look and here are links to S-330 and S-550 versions of director-S
http://www.sgroup.ca/archive/os/
Jonny Jones
Fatbenelton
Postby D-Collector » Fri Jan 24, 2014 2:38 pm
Yes, but those files hosted on sgroup require a dongle to be fully functional.
D-Collector
Postby Silverfish » Sat Jan 25, 2014 7:02 am
Did anyone ever try my re-hacked S-550 Director-S disk image? I never did test it myself. I should still have it, if anyone is still interested. No guarantees that it actually works, though. :D
Silverfish
Real name: Tyler
Band: Silverfish
Postby Don Solaris » Tue May 13, 2014 11:29 pm
Silverfish wrote:Did anyone ever try my re-hacked S-550 Director-S disk image? I never did test it myself. I should still have it, if anyone is still interested. No guarantees that it actually works, though. :D
I'd like to try it. Just restored my S-550. It's finally working right.
Don Solaris
Gear: I got almost everything you would ever want.
Postby Silverfish » Wed May 14, 2014 6:38 am
I'll see if I can track it down here...
Silverfish
Real name: Tyler
Band: Silverfish
Postby bassmobile » Fri May 16, 2014 3:38 am
Thanks in advance,
Dmitriy
No problemo friend.
:thumbright:
:cry: The ZIPPYshare links are down? Any chance you could re-up these disks?!
Anyone else. Looking for the dongle free version of Director S for the S-330!
bassmobile
Return to Samplers
