equipment that instantly inspires workflow
princefan3
Post by princefan3 » Thu Dec 08, 2011 3:28 pm
just purcahsed a Roland 707 on monday.
not only is it an instant machine with a groove, but a very close impression to the Linn LM1.
it sits in the mix well, with a little tinkering.
but to get ideas written down quick, you cant go wrong with this baby.
is there any other equipment you could mention that enables such easy workflow.
JJQ
Re: equipment that instantly inspires workflow
Post by JJQ » Thu Dec 08, 2011 4:03 pm
101/202/303/606/808/909 :)
Gear: Minimoog, Mother-32, Roland MC-202, TB-303, (Boss) DR-110, TR-505, TR-808, Alpha Juno 2, Jupiter-8, Oberheim SEM, .com/oakley/moon/mos-lab/STG/Sputnik/MegaOhm-modular & Microbrute
Z
Post by Z » Thu Dec 08, 2011 4:07 pm
My JD-800 is usually the first synth I power on in my rig and start tweaking to my current mood.
cgren72
Post by cgren72 » Thu Dec 08, 2011 4:25 pm
i think this may be because it was my first synth, but my korg poly 800 always is easy to use and write on. mine has the filter and "fm" knobs, but even without them, i can still write easily. it was the same way with my dw-8000. with too many knobs i actually sometimes get distracted, and when im using software i usually just assign a few knobs on my controller to filter or other parameters.
for me, keeping it simple is better than having alot of knobs.
but to answer your question, the older korgs are really easy to use
deeplow
Gear: bad luck brain
Post by deeplow » Thu Dec 08, 2011 4:35 pm
elektron machinedrum
"You can never underestimate the amount of unimaginative people out there making music." Stab Frenzy
garranimal
Post by garranimal » Thu Dec 08, 2011 9:15 pm
deeplow wrote:elektron machinedrum
God yes I'll hop on that bandwagon right away.
There's something about loading up piano samples or Rhodes plugin (like Mr Ray) that get the good vibes going.
And especially a good old stringer that uses BBD chips.
Sir Nose
Real name: Bob
Post by Sir Nose » Fri Dec 09, 2011 4:22 am
Machinedrum ++
Funkadelic wrote: nothing is good unless you play with it
all that is good is nasty
Mr Knesh
Real name: Roland
Gear: DP/4+ because in order to dive in deep, you have to DP.
Post by Mr Knesh » Fri Dec 09, 2011 4:34 am
princefan3 wrote:equipment that instantly inspires workflow
I like the kind of equipment that makes noises when you touch it.
philip
Real name: Philip
Post by philip » Fri Dec 09, 2011 4:52 am
piano
Shreddie
Gear: Alesis Andromeda, Fusion 8HD: ART SGX Nightbass SE: Kawai K5000s: Yamaha A3000 V2, EX7, FS1R, PSS-480 (Don't laugh, it rocks!) and 4 planks.
Post by Shreddie » Fri Dec 09, 2011 4:53 am
Mr Knesh wrote:I like the kind of equipment that makes noises when you touch it.
:lol:
phesago
Real name: Douglas
Gear: tech nine, bag of coke, an erection and a hostage
Post by phesago » Fri Dec 09, 2011 7:55 am
:D
But in all seriousness besides the awesome drum machine already mentioned, all those fancy knobular analog synths are awesome at being just that.
burnn_out!
Post by burnn_out! » Fri Dec 09, 2011 8:03 am
personal fav is my metasonix d-1000. Close seconds are the vostok, drone commander, ms-20
DIGITAL SCREAMS
Band: Digital Screams
Post by DIGITAL SCREAMS » Fri Dec 09, 2011 8:31 am
princefan3 wrote:just purcahsed a Roland 707 on monday.
Your right...for a long time the TR707 was my goto drum machine....because it was so quick and easy to get a groove going. Run the individual outs into some nice outboard and your good to go. I tried to get to grips with Stylus and although I respect it for being increadibly versatile and powerful...I found it totally got in the way of knocking out quick grooves. I know its because im still quite nooby...but it highlights the importance of using gear that not only sounds good...but is pitched at the right level so you can actually use the bloody thing.
I used to use the 707 with a ProOne, Prophet 5, Jupiter 8 and Juno 60. Nice simple set up. My workflow slowed right down when I moved over to a DX7 and D50. Access Virus is ok....if you use it as a simple synth.
Synthesizers: Roland Jupiter 8, Sequential Prophet 5, Moog Old School, Access Virus TI2, Yamaha DX7 MKII (and FM8), Roland D50, Korg Wavestation and M1
Website: http://www.youtube.com/user/DIGITALSCREAMS
iProg
Real name: Carl
Band: ArtWithHeart
Post by iProg » Fri Dec 09, 2011 8:56 am
Any synth without patch memory.
That makes me start fresh every time and not just play stuff via presets. Which is a current problem with me and the VS. It has so many great sounds that I don't tweak it enough.
tekkentool
Real name: Steve
Band: none currently
Post by tekkentool » Fri Dec 09, 2011 2:13 pm
philip wrote:piano
This.
