Ensoniq ESQ1
Ensoniq ESQ1
Postby man-009 » Thu Dec 29, 2011 3:28 am
Fires up fine. Patches load..but I don't have any audio coming out of the left or right..nor will it transmit any midi info.
man-009
Band: Man-009
Re: Ensoniq ESQ1
Postby Stab Frenzy » Thu Dec 29, 2011 4:38 am
Have you tried playing it with another keyboard via the midi in? I've fixed up ESQ-1s with corroded traces on the keyboard PCB before which resulted in various keys not working, yours might be like that but so bad that none of them work.
Re: Ensoniq ESQ1
Postby man-009 » Thu Dec 29, 2011 9:07 pm
Nope. However I did get the battery voltage low message. That's new. Ha. Nothing from my other board though. Midi set to omni on both. maybe the battery change will fix it?
man-009
Band: Man-009
Re: Ensoniq ESQ1
Postby rhino » Fri Dec 30, 2011 12:03 am
Try a reset. With the power on, press and hold "record" and then press the top left "soft" button over the screen.
Answer "yes".
QUESTIONS:
(1) did this just start, or did you buy it this way?
(2) is the kwyboard enabled in the "master" menu?
(3) Check the connector to the keyboard and its cable
You need a new battery, but don't expect it to fix THIS problem.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Ensoniq ESQ1
Postby man-009 » Sun Jan 01, 2012 1:50 am
nothing after the reset..:(
man-009
Band: Man-009
Re: Ensoniq ESQ1
Postby rhino » Sun Jan 01, 2012 4:04 pm
man-009 wrote:nothing after the reset..:(
Do you mean "no change". or entire unit is dead?
Broken, corroded or loose keyboard cable is a common problem on these and the SQ-80.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Ensoniq ESQ1
Postby man-009 » Mon Jan 02, 2012 7:05 am
no change...
man-009
Band: Man-009
Users browsing this forum: Baidu [Spider], Google Adsense [Bot] and 1 guest
