dead microkorg
Re: dead microkorg
the end...good luck all with your dead synths.
- die monster die
- Real name: Pierre
- Gear: MS10, Monopoly, Synare S3X, Microkorg, DDD1, Prodigy, UpOne, MFB502, Mopho.
Re: dead microkorg
I'm having the exact same issue with a MS2000. Very similar to microkorg's power supply.
Voltage regulator S8520F33 and fuse CCP2E20 are dead.
It might depend on the country but you can order them from Korg.
Prices i had here (France) were:
S-8520F33MC = 5,85 €
CCP2E20 = 1,5 €
The regulator feeds the CPU, it might be allright, but i afraid the CPU is dead too.
CCP2E20 = 1,5 €
Re: dead microkorg
good luck!.. i have a new prob. There are two diodes that could have blown out in my AC adpter path. Mine only works with batteries. I wonder if you can hardwire the adapter wires to the battery leads for power? It's all 9v right?
Re: dead microkorg
not going to risk the bypass..
- die monster die
- Real name: Pierre
Re: dead microkorg
Power section is now in working condition.
The LCD screen says "Chck Sum Error". I have no idea what this means.
No mention in the owner or service manual. I believe something else fried.
- Stab Frenzy
- Moderator
Re: dead microkorg
Google checksum to see what it means, it'll be easier than me explaining it here. Basically checksum error means that the OS has become corrupted and the synth realises it and so is not attempting to run it. Not sure what course of action to take to fix it, but it's quite likely that the synth is now only good for parts.
Re: dead microkorg
hi and i thank everrone in this thread for the info on fixing my dead microkorg.. i bought the needed parts off ebay from china, and i had to buy 5 of each part..l . needless to say after grtting it fixed i have 4 each of the 2 parts needed. if anyone in vermont,new hampshire, massachusetts,usa ,etc needs these parts i can meet you and more kess give em to ya for a cup of coffee or a beer ..
the 2. parts are the S-8520F33MC-BNST2G regulator and the 3 volt ic XC61CN3002MR(the 3pin one).i do not use paypal otherwise id offer these to any non local fellow korgies that need them ...
- Stab Frenzy
- Moderator
Re: dead microkorg
Just a note here in case anyone comes across this because they can't find the now obsolete S-8520F33MC voltage regulator, I found an equivalent part with the same footprint. It's the Ricoh R1223N332H-TR-FE just replaced one in a Microkorg here and it's now successfully delivering 3.3V on the digital line.
Re: dead microkorg
Looking for a little help from one of the folks who recently fixed there micro kong. My Son's micro korg does not power up at all. He had let a buddy borrow and I'm guessing he using the wrong power supply. Can someone walk me through the repair in a little more detail than is here in this string? I'm have a DMM and a good soldering iron (and a micro miniature repair specialist at work as well) and I do restore and sell vintage HiFi equipment so I think I could handle just can't figure out what folks are doing exactly. Thanks!
Re: dead microkorg
I appreciate this is a long shot, asking 5 years after it’s been posted... but I’m hoping adhmzaiusz might be able to answer a question for me
I’ve got a friend’s microkorg board infrobt of me and looks like the EMI filter has gone (continuity on all legs)
You mentioned about bridging this - just curious as to which tracks you bridged. I guess I could trial and error it but some help would be amazing!
Thanks so much for all the posts everyone - really helpful
*edit*
Don’t worry! I took out the broken EMI filter, tried bridging it the way I assumed it would go and success! A working microkorg!!
thanks adhmzaiusz - wherever you may be. 5 years on and you’re still shooting troubles!
*edit*
- Gear: Yamaha DX27S
E-MU Proteus MPS Plus Orchestral
Korg MicroKorg
Dave McMillen 12 Step
Re: dead microkorg
I had the same issue, and the fix was easy. I found a common mode choke made by TDK that I replaced the M522C component with and it works perfectly. Thanks adhmzaiusz!Asp102 wrote:I appreciate this is a long shot, asking 5 years after it’s been posted... but I’m hoping adhmzaiusz might be able to answer a question for me
You mentioned about bridging this - just curious as to which tracks you bridged. I guess I could trial and error it but some help would be amazing!![]()
*edit*
Don’t worry! I took out the broken EMI filter, tried bridging it the way I assumed it would go and success! A working microkorg!!thanks adhmzaiusz - wherever you may be. 5 years on and you’re still shooting troubles!
Re: dead microkorg
Hey guys, I'm trying to fix a micro korg,
It wont power on or anything, however on battery power it does heat up the d3 and d6 components.
any ideas?
is the IME filter the one located on L8? is this related?
there's no signs of damage to the component.
I can resolder components, but finding the bad ones is where I'm not so experienced
any ideas?
Re: dead microkorg
Probably not much help to you, but I fixed my microkorg this week. Four keys were dead and the 1 button and shift button dead too.
Turned out to be a split track down at the bottom right hand side of the top of main board. Such a small split I had to use a macro lense to see it.
It’s always been in my studio so it must’ve just burnt itself out over time.
Get a magnifying glass and go over every single bit and see if you can spot any marks then continuity test that section of track as it seems to be a common thing on this synth.
Good luck.
Good luck.
