KORG MS10 with stereo headphones
Postby arminp » Tue Jul 03, 2012 6:11 pm
Hey guys,
I recently bought a KORG MS10, which I was looking for for a really long time! I can really recommend it to anyone looking for an analog synth..
However, I encountered a small problem.. Since the synth is monophonic, I only hear the left channel when I plug my normal headphones into the "signal out" jack.. It obviously works normally when I plug it into an amp or a mixer..
Is there a way to "double" the signal in order to be able to listen to what I play with normal stereo headphones? I'd love to take the synth to some places where there is no mixer around just to jam a bit..
Thanks a lot in advance,
Armin
arminp
Re: KORG MS10 with stereo headphones
Postby V301H » Tue Jul 03, 2012 6:54 pm
You might see if a local music or electronics store has a Stereo-to-Mono adapter plug something like this:
http://www.showmecables.com/product/1-4 ... 4AodTwq3Cw
Prophet 5 rev.2, Pro-One, Juno 60, Jupiter 6, Matrix 12, OB8, MS20, Poly 800, CS70M, DX-7, CP35, Casio PX-5S, Hammond C3/M102, Vox Continental/Super Continental, Gibson G101, Farfisa Compact, RMI 300A, Pianet N, Combo Pianet, S770, S760, S50
V301H
Band: The Characters
Postby pflosi » Tue Jul 03, 2012 8:16 pm
arminp wrote:Since the synth is monophonic, I only hear the left channel when I plug my normal headphones into the "signal out" jack...
No, since the synth is monophonic, you only can play one note at once. Since the synth has no headphone output, you only hear the left channel when you plug your normal headphones into the "signal out" jack... ;)
Postby arminp » Tue Jul 03, 2012 9:23 pm
Thanks for rectifying :)
I went to a shop today to ask for that kind of cable or adapter, but they said it wouldn't be such a good idea as there is some problem with the headphones impedance.. They said it might destroy the synth from the inside or something, I didn't quite get what they meant..
I guess I'll have to stick to my mixer then..
arminp
Postby madtheory » Tue Jul 03, 2012 9:39 pm
You won't destroy anything. But the "signal out" socket is not for headphones, it's for the line input of a mixer or similar. If it was for headphones it would say "headphones". :P But you've discovered that by trial and error now, so it's all good.
Nice synth!!
Band: madtheory
Postby rhino » Tue Jul 03, 2012 11:07 pm
One possible solution might be one of those tiny headphone amps made for electric guitar practice. I'll edit this post when I find a link.
Here is one version:
http://www.sweetwater.com/store/detail/amPlugAC30
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby fh991586 » Wed Jul 04, 2012 4:15 am
But still, what's the real problem with using an signal output if there is not headphone output?
-Roland TR707
-Yamaha DX7
-DSI Mopho
Gear for Sale: Roland M-OC1, M-BD1
fh991586
Real name: Francis
Gear: Roland Juno 106, JX3P, D50, U220, MVS1, JP8080.
Yamaha Motif Rack.
TherapSid
Postby Stab Frenzy » Wed Jul 04, 2012 6:13 am
fh991586 wrote:But still, what's the real problem with using an signal output if there is not headphone output?
For a start, you only get signal to the left side of the headphones...
Postby Don T » Wed Jul 04, 2012 6:19 am
Usually there is not enough power to drive the headphones, at least not at a useable level. By looking at the MS-10 service manual, if you are able to hear anything through your headphones, it's probably weak, or the headphones are amazingly sensitive.
Don Taylor
Master of no trades, practitioner of many.
(Basically, this means I know just enough about a lot of things to get myself in real trouble)
Don T
Real name: Don
Postby fh991586 » Wed Jul 04, 2012 11:44 pm
When I test a synth before buying it, and there is no amp available, I check the signal output(s) with my cheap walkman headphones, and I can pick up the sound. It's not enough nor fun to play long like this, but it's still a possibility...
Just tell me there is no possible damage to the synth itself (why could there be anyway?), and the rest is irrelevant to me.
-Roland TR707
-Yamaha DX7
-DSI Mopho
fh991586
Real name: Francis
Yamaha Motif Rack.
TherapSid
Postby rhino » Thu Jul 05, 2012 12:42 am
Looking at the MS-10 schematic, the output is single ended, capacitor coupled. There is no logical way you could hurt the synth by using a mono to stereo adaptor on your headphones. You will have a rather low level signal, and loose much of the bass response due to the mismatch, but no damage.
Most synths in the past 20 years have a stereo headphone jack (with built-in amps to boost the level)
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby Sexor » Thu Jul 05, 2012 4:17 am
Maybe you should try this then:
Same link
Monkey business since 2007!
Sexor
Gear: Prophet6, Jupiter-7, MS25, Juno-50, TR-303, Rhodes 63
Postby Projectile » Sat Jul 07, 2012 5:54 am
The guys at the shop are idiots. You won't hurt the synth by using a mono to stereo adapter and plugging headphones into the line out. Though, it will sound pretty crappy without a headphone amp. I would recommend getting one of those cheap little battery powered headphone amps to boost the signal and give you the right output impedance. That should do the trick.
Projectile
Postby fh991586 » Sun Jul 08, 2012 5:18 pm
That's what I thought. Thanks for the precision.
-Roland TR707
-Yamaha DX7
-DSI Mopho
fh991586
Real name: Francis
Yamaha Motif Rack.
TherapSid
Users browsing this forum: No registered users and 16 guests
