For first analog synth, Moog Prodigy Or Moog Source?
Re: For first analog synth, Moog Prodigy Or Moog Source?
Postby Automatic Gainsay » Wed Aug 08, 2012 3:02 am
silikon wrote:If you're staying within relatively inexpensive vintage moog mono, (relative to a minimoog, for example) then Micromoog..
Oh, my GOD, absolutely. THIS.
Automatic Gainsay
Real name: Marc Doty
Band: Godfrey's Cordial
Postby sam » Thu Aug 23, 2012 8:55 pm
Go for the prodigy even if it's not your first synth....Such a nice sweet synth..
ms20/50.Andromeda. OBX.
sam
Postby iProg » Thu Aug 30, 2012 12:03 pm
I can highly recommend the Prodigy. So easy to create sounds with! And recreate them...
iProg
Real name: Carl
Band: ArtWithHeart
Postby philip » Thu Aug 30, 2012 10:22 pm
Prodigy
philip
Real name: Philip
Postby maxwellravitz » Tue Sep 11, 2012 7:38 am
I would also have to say the prodigy. Not only does it have dedicated knobs for every parameter, but you won't have to deal with the source's membrane button maintenance. Sound-wise, I have to say the two are extremely simliar, but not exactly the same. Programming is where the two deviate. When programming the source, you have to hit a button then turn the single knob, so you can't change multiple parameters at once. The only thing the source has over the prodigy is patch memory. After owning a prodigy for awhile, I would have to say they're really good for learning subtractive synthesis, and a lack of patch memory forces you to learn the nuances of the controls much better.
maxwellravitz
Previous
Users browsing this forum: Bing [Bot] and 2 guests
