best 'choir' patches?
garranimal
Re: best 'choir' patches?
Post by garranimal » Wed Oct 24, 2012 3:10 am
cornutt wrote:
garranimal wrote:The Kawai K5000 series synths are most excellent for choir, has a 128-band formant filter.
It does? Damn, I didn't know that. I knew it had a lowpass filter, but... Question that occurs to me: Is it really a filter, or is it manipulating the partial levels in the additive engine.
I'm all jealous now... the K5 doesn't have that.
That's the kicker, it has it ALL. Yes there's a lowpass filter. Yes the additive sound engine has full control for setting the starting partial values, and has a level envelope for each and every partial that makes up your patch....
AND THEN passes this audio through a fully independent 128-band formant filter. Each and every formant band has its own level setting. If that seems too static, the formant filter also has a dedicated envelope contour to animate the sound further. Think of the formant filter envelope as an EQ boost or cut that can start anywhere in the formant range and sweep up or down to emphasize/de-emphasize parts of the formant filter range over time. It's mind boggling.
DesolationBlvd
Post by DesolationBlvd » Tue Nov 06, 2012 2:27 am
I stupidly wiped my MKS-80's tones and patches trying to load the factory presets.
I got a great analog choir out of the Alpha Juno. The secret is the "PWM sawtooth", medium resonance (not too high, otherwise it "rings"), and of course the internal chorus.
Moog Matriarch
Oberheim OB-8/DSX/DMX
Sequential Prophet 2002/Prophet-5 rev. 4
Ensoniq Mirage/SQ-80
Roland JP-8/SH-101/RS-09/Kiwi-30
Korg MS-20 Kit/ARP Odyssey FSQ
Yamaha SY99/DX100
Waldorf Microwave 1
Simmons SDSV
Elektron Analog RYTM
nvining
Gear: CS80, Chroma, Synclavier, DK Synergy II+, Matrix 12, Memorymoog+, CS20m, Clavinet, AlphaSyntauri, Korg Micropreset, Lexicon 480L, Otari RADAR
Post by nvining » Tue Nov 06, 2012 2:52 am
One of the choir patches that comes with the Rhodes Chroma CC+ Upgrade is pretty good, especially with a little bit of reverb. I think it's bank 3, patch 36 or something like that. Then again, everything sounds good with enough reverb.
While I don't own one, I've also been listening to demos of the Yamaha FS1R recently, which seems to do a lot of interesting things with its "formant filtering". Sounds fun to my ears, but then I have yet to actually get ahold of a unit to test.
"We have to remember that Moogs, ARPs and all of the first synths had been created by raging madmen." - Jean-Michael Jarre
Zamise
Gear: Rollhand P00
Band: Quantum-Source
Post by Zamise » Tue Nov 06, 2012 8:35 am
I don't know, but my RS7000 has a couple choir voices. I think if you prob put a lo-fi around 1.2 khz give a little tweek around that while you play effect plus talk modulation, beat all the above posts.
tekkentool
Real name: Steve
Band: none currently
Post by tekkentool » Tue Nov 06, 2012 9:46 am
Like...bitcrushing down to 1.2 Khz?
good choir?
Wat?
orlando56
Gear: Prophet 600, MiniKorg 700, Juno 106, Polysix, Little Phatty II SE, Poly 800, MS20 Mini, Behringer D, KARP Odyssey
Band: Squirrel Damage
Post by orlando56 » Wed Nov 07, 2012 12:45 am
Does the Polymoog Vox Humana patch count? In any case, one of the greatest synth sounds ever.
Zamise
Gear: Rollhand P00
Post by Zamise » Wed Nov 07, 2012 6:06 am
tekkentool wrote:Like...bitcrushing down to 1.2 Khz?
good choir?
Wat?
Yeah maybe, gives it a more vocal sound, maybe, robotic choir ;)
ItsMeOnly
Post by ItsMeOnly » Wed Nov 07, 2012 9:26 pm
Best realistic choir? Prosonus library (also for CMI series III).
vcs3
Post by vcs3 » Thu Nov 08, 2012 11:25 am
Don't forget the Yamaha FS1r choir.
mama.
Post by mama. » Thu Nov 08, 2012 6:29 pm
Does anyone else find choir patches unsettling? I have 3 of 4 different collections of mellotron choir samples, and an e-mu emax with the "mixed choir" factory disk... from what I can tell, these samples are recordings of actual zombies.
cornutt
Gear: 6th
Post by cornutt » Thu Nov 08, 2012 8:41 pm
mama. wrote:Does anyone else find choir patches unsettling? I have 3 of 4 different collections of mellotron choir samples, and an e-mu emax with the "mixed choir" factory disk... from what I can tell, these samples are recordings of actual zombies.
Shh! Jeez, they'll hear you! :?
Post by madtheory » Tue Nov 13, 2012 1:00 am
Yes! The Melly was often referred to as dead people singing. That was before zombies were pop culture.
tekkentool
Real name: Steve
Post by tekkentool » Tue Nov 13, 2012 1:09 am
I love mellotron samples, the AHHHRHGRHRGRHRGRHRGHRGR is perfect.
impaler42
Real name: Shaikat
Gear: Ensoniq Fizmo, Yamaha FS1R, E-mu Ultra Proteus, Korg Wavestation SR, Waldorf Blofeld
Band: Grainshifter
Post by impaler42 » Tue Nov 13, 2012 5:05 am
The FS1R is capable of some cool choir type sounds using formant shaping.
electronic music forever
http://www.grainshifter.com[/url]
balma
Real name: Mauricio
Post by balma » Wed Nov 14, 2012 1:06 am
One of the best choirs patches I´ve programmed on the E-mu command station. Simple but effective. This choir leads the whole feeling of this song.
Starts at 0:34
https://soundcloud.com/balma
