Fairlight IIx library, floppy conversion! UPDATED 13.01.13
Re: Fairlight IIx library, floppy conversion! UPDATED 13.01.
Postby D-Collector » Sat Jan 19, 2013 9:46 am
Thanks LBN!
I've added your mirror to the OP!
D-Collector
Postby 8bit9bot » Sat Jan 19, 2013 2:49 pm
another mirror: http://alexmauer.com/dl/FAIRLIGHT%20CMI ... IBRARY.zip
i emailed you about this... i have other fairlight disks which were not part of the original library in IMD format... are you interested in converting them as well? the disks have names like: dreams, linndrum, linnstuf, simmons1, orch1 - this all sounds interesting to me and i always wondered what was on these disks
8bit9bot
No Longer Registered
Postby D-Collector » Sat Jan 19, 2013 7:32 pm
Thanks! Mirror added to the OP.
The disks you speak of, they are the ones found here right?
http://cmi.fairlightus.com/fairlight_floppies/IIx_disks/Jeff%20Disks/
I tried a couple of those, dreams.imd and another one. CMIOS9 did not recognize them unfortunately.
I'll take a look at more, let's hope at least some of them can be exported.
D-Collector
Postby 8bit9bot » Sat Jan 19, 2013 9:42 pm
D-Collector wrote:Thanks! Mirror added to the OP.
yes those are the disk images i was talking about
8bit9bot
Re: Here is the Fairlight IIx library, straight from floppy!
Postby silikon » Sun Jan 20, 2013 3:22 am
D-Collector wrote:It's all good then!
Let's celebrate with some of Trevor Horn's excellent 12" remixes of Frankie. These were uploaded by Hashmoder, you should all check out his outstanding blog dedicated to vinyl rips of rare 12" versions http://www.hashmoder.com/. To quote him:
I want you to listen to these tracks carefully all the way through … in front of big, beefy stereo speakers:
:dancer:
A bit belated as it were, but I just wanted to thank you for this post specifically. Huge admirer of Trevor Horn's work. Also, a mighty cheers for your work done here. Exemplary.
echo 1 > /dev/awesome
silikon
Real name: Ms. Jackson
Band: Year with no summer
Postby D-Collector » Sun Jan 20, 2013 11:31 am
Thanks silikon! If you like those mixes, you should check out ZTTs The Art Of The 12" Vol.1 + 2, if you haven't already done so. You will find these, and more awesome 12" Frankie mixes, as well as Art of Noise, Scritti Politti, Propaganda, etc!
Excellent set of CDs!
D-Collector
Postby Tea » Mon May 08, 2017 4:55 pm
Just curious, how did you extract the sounds using cmios9? I've read the readme but am completely stuck on this one. Do you have to mount the .imd images or do you use the .bin files converted from the .imd images?
Really not sure on this one.
Thanks.
Tea
Previous
Return to Samplers
