Problem with modulation section in Moog Little Phatty
Postby reaman » Sat Mar 02, 2013 8:25 am
Hi everyone!
A couple days ago, I bought a Little Phatty. All section is working good, but the modulation section does not work at all. Is it defect or i need to use something settings?
Thanks in advance!
reaman
Re: Problem with modulation section in Moog Little Phatty
Postby GuyaGuy » Sat Mar 02, 2013 8:37 am
Make sure you either activate the modulation with the mod wheel or press and hold the Amount button to use that as the mod wheel. At "zero," there will be no modulation. If it's still not working you should probably contact Moog.
GuyaGuy
Gear: YES PLEASE!
Postby reaman » Sat Mar 02, 2013 9:06 am
GuyaGuy wrote:Make sure you either activate the modulation with the mod wheel or press and hold the Amount button to use that as the mod wheel. At "zero," there will be no modulation. If it's still not working you should probably contact Moog.
Maybe, I missed this point, but how can i activate the moulation with the mod wheel?
reaman
Postby GuyaGuy » Sat Mar 02, 2013 9:10 am
Just roll it forward. By default it's off. Roll the wheel forward and you should hear whatever modulation is dialed in.
GuyaGuy
Gear: YES PLEASE!
Postby reaman » Sat Mar 02, 2013 12:38 pm
GuyaGuy wrote: Just roll it forward. By default it's off. Roll the wheel forward and you should hear whatever modulation is dialed in.
No, it's still not working. Try to write in a Moog support.
Thank You!
reaman
Postby Bitexion » Sat Mar 02, 2013 12:46 pm
Most presets should have the modwheel do a vibrato or open filter cutoff when you push it forwards. If it's not working at all, your modwheel is probably broken.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Postby Em Pe Ge » Sat Mar 02, 2013 3:33 pm
You should also try turning up the LFO rate, and more importantly the amount.. some patches have the amount turned very low, could be the issue.
Em Pe Ge
Gear: Akai MPC1000, Moog Slim Phatty, Roland Alpha Juno 1, Animoog (via iRig midi), Ableton Live, Reason.
