Desktop Monosynth
- Sir Nose
- Senior Member
- Real name: Bob
- Gear: Machinedrum, Octatrack, Moog LP, x0xb0x, Elka Solist 505, Simmons SDS-400
Desktop Monosynth
I am considering a small desktop synth for when I do not want to take the phatty out of the house. Budget is a plus.
Micromac: out of my league
SEM: a used midi version might be the ticket
Will I miss the patch panel that much? The Pro is in the same range as the elektron A4. I would have a tough time not going for an A4 over a SEM pro.
Dark Energy I & II: not sold on the tone
Vermona Lancet: front runner so far
Minitaur
So many others on the market.
Minitaur
Funkadelic wrote: nothing is good unless you play with it
all that is good is nasty
- shaft9000
- Real name: Dave
- Gear: Whips chains waxes oils dildos DMT TNT the LHC, and a black rubber duckie
- Band: moneymoneymoney
Re: Desktop Monosynth
Futureretro XS and MFB dominion x are worth a look, too
the SEM eats the A4 alive in raw tone...the A4 sounds very good, sure, but there is a difference between 4 duplicate voices+sequencer+FX vs. just ONE voice for similar money. the SEM is one of the out-and-out CLASSIC monosynth sounds and hasn't really been beaten at what it does in 40 years.
if you get the patch panel be sure to get some attenuator modules. attenuators are passive, so you don't need a PSU or case at all to use them.
- Z
Don't forget the MFB Kraftzwerg.
I originally had the patch panel version of the new SEM and sent it back to Tom for the Pro upgrade last year. Like Shaft said, the SEM has a classic sound and the multi-mode filter is so versitile. If you don't want to srping the extra $ for the Pro, get the patch panel if you've got a MIDI/CV converter.
Though I haven't heard it yet, the ARP filter Boomstar would be a good choice, too.
- Jabberwalky
- Gear: A hybrid of vintage and modern junk
- Band: Variar
There's also the FR777. The new Waldorf Rocket looks cool and very small too.
- megamanx
- Senior Member
- Gear: nord lead2, roland sh101, yamaha cs5,mono/poly, sub37,Ms20, Chroma polaris,prodigy, esq-1, jx3p
- Band: Thieves & Co.
slim phatty
shaft9000 wrote:Futureretro XS and MFB dominion x are worth a look, too
Who makes the SEM & Micromac?
- Z
SEM (Synthesizer Expander Module) www.tomoberheim.com2manydrummachines wrote: Who makes the SEM & Micromac?
MicroMac - www.macbethstudiosystems.com/
Hey thank you for the information. Have you seen the smaller monophonic synths? I was looking for one of those. It's a German manufacturer and from what I saw of it, it only has MIDI in and audio out. I will know it when I see it.
- Sir Nose
- Senior Member
- Real name: Bob
Waldorf Rocket or Pulse 2
Doepfer Dark Energy
Vermont Lancet
Doepfer Dark Energy
Vermont Lancet
- meatballfulton
- Moderator
- Gear: Logic Pro X
Ploytec P-L squared2manydrummachines wrote:It's a German manufacturer and from what I saw of it, it only has MIDI in and audio out.
No these aren't it either.meatballfulton wrote:Ploytec P-L squared2manydrummachines wrote:It's a German manufacturer and from what I saw of it, it only has MIDI in and audio out.
- Junior Member
- Real name: Vincent
- Gear: ESX, MPC 2500, EPS16+, TX16w, TX81z, Micro Q, Microbrute, Bass Station 2, MS-20 Mini, Nord Lead 2, Machinedrum, D-50, QS7.1, loads of effects...
- Band: Purplewave
Technosaurus Microcon II... very small size, sturdily built, FAT analog sound. (Hard to find though.)
- Weirdofromouterspace
- Real name: Bodo
- Gear: MFOS SLMS+ & Ultimate, TTSH, DX7IID, DX21, Minibrute, Poly-800, microKORG, microSAMPLER, Volca Beats & Bass, JX-03, Tr-8, Kawai K1, Jasper
Arturia Minibrute. Great sounds, well built (except maybe for the keyboard weights, which may need to be glued on back again after they fell off
), and great value for the money.
Don't forget to TURN ON THE SYNTHESIZER. Often this is the reason why you get no sound out of it. - ARP 2600 manual, 1971
- ryryoftokyo
- Real name: Ryan
- Gear: Metal, plastic, wood, and electricity.
- Band: Tarot Sync
DSI Mopho desktop?
