I think that's in keeping with the Volca-esque character of the machine. Only the bare essentials here. Which is too bad, really, because it would be terrific if you could use the sequencer to play other synths via MIDI.pflosi wrote:And no DIN midi out...
New analog Arturia synth?
- Real name: Aaron
- Gear: Pioneer: Toraiz SP-16
Elektron: AK, AR, MnM, MD, OT
DSI: Evolver, MEK, P08, Pro2
Korg: Arp Odyssey
Waldorf: Blofeld Keyboard - Location: Phoenix, AZ
Re: New analog Arturia synth?
- Real name: Aaron
Korg: Arp Odyssey
Does the Micro run on batteries? In the teaser video, it's being played on a train, so I assume it does. Or do you have electrical outlets on the trains in Europe?
- yorgatron
- Junior Member
- Gear: ARP Axxe
ARP Omni I
Korg Poly-61
Korg MS-10
Korg Mini-Korg 700
Elka X-55
RMI 300A
Wurlitzer 206A
Hohner Clavinet/Pianet Duo
Casio XW-P1 - Band: Asha-Med
Dr. Phibes wrote:Good to see they've listened to the public and done something about the minibrute's unwieldy size.
what's that other synth she's playing on stage, Polysix?
- megamanx
- Senior Member
- Gear: nord lead2, roland sh101, yamaha cs5,mono/poly, sub37,Ms20, Chroma polaris,prodigy, esq-1, jx3p
- Band: Thieves & Co.
mono/poly
- Kenneth
- Real name: Kenneth
- Gear: Nothing I own will make you jealous.
- Band: KGB
Seems really convenient, but I really don't like the character of the Brutes. Just too shrill and brittle for my tastes. I'm going with the Volcas.
- pflosi
Actually, we do.Aaron2 wrote:Does the Micro run on batteries? In the teaser video, it's being played on a train, so I assume it does. Or do you have electrical outlets on the trains in Europe?
- spookyman
- Gear: cheezy machines and some cheap analog stuff
I thought it was a Korg Delta ?megamanx wrote:mono/poly
- Psy_Free
- Gear: Synths 'n' stuff.
- Band: Klangzeit
It is a Delta.spookyman wrote:I thought it was a Korg Delta ?megamanx wrote:mono/poly
Good to see the Microbrute isn't a VA after all
- megamanx
- Senior Member
yep delta, my bad...
- spookyman
It has midi over usb, it's better than nothing. But of course, not the best solution if you want to use the sequencer to play synth that has only a 5pin midi-in.Aaron2 wrote:I think that's in keeping with the Volca-esque character of the machine. Only the bare essentials here. Which is too bad, really, because it would be terrific if you could use the sequencer to play other synths via MIDI.pflosi wrote:And no DIN midi out...
But you have CV/Gate outputs, so you can play analog modules that have CV/Gate In connections.
- pflosi
^ Yeah but I need a small midikeyboard (normal power not that USB stuff with DIN midi plug) anyways to input notes into my sequencer - the Microbrute would have been perfect to do that and then some more. There's no midi keyboard this small that has a standard power connector and DIN midi, only this newfangled USB stuff... Would have been two birds with one stone for me... And no, I'm not gonna plug a computer in between just for a midi out...
Microbrute looks cool nevertheless, now the thing that will determine everything for me is how the sequencer works. If it's near the coolness of the SH101 sequencer I might get it even just for that...
- meatballfulton
- Moderator
- Gear: Logic Pro X
So buy used. Or get one of those idiotic Kenton boxes for $100pflosi wrote:There's no midi keyboard this small that has a standard power connector and DIN midi, only this newfangled USB stuff...
- pflosi
Used? Problem is don't know for sure what to buy (best match I found so far is Alesis Q25)
Kenton box looks good though, didn't know that. Bit pricey of course.
Anyway, back to the Microbrute gents
- Gear: Juno 106, Tetra, Mopho Keyboard, Little Phatty Stage II, RX-5, Volcas, JX-3P, R5, 505, TX-7, D550, TX81Z, Korg MS-20 Mini, Minibrute, Six Traks, TR-8
Kenneth wrote:Seems really convenient, but I really don't like the character of the Brutes. Just too shrill and brittle for my tastes. I'm going with the Volcas.
