Arp Omni 2 tuning pot?
Postby Europanaut » Thu Oct 31, 2013 11:09 pm
The whole thing is a few cents sharp, enough to cause problems in the studio. There's no adjustment on the outside, so I assume that there's a trim pot on one of the boards. Has anyone here tracked down the appropriate master tuning pot? The overall calibration across the keyboard is fine, it's just the master tuning that's out.
Europanaut
Re: Arp Omni 2 tuning pot?
Postby rhino » Fri Nov 01, 2013 12:10 am
It is a coil, not a pot. Located on the UPPER VOICING BOARD. Very likely in a small metal can. Use a non-ferrous screwdriver to adjust it.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby Europanaut » Fri Nov 01, 2013 1:12 am
L1, 220, I assume. According to the service manual diagrams.
Europanaut
Postby rhino » Fri Nov 01, 2013 1:30 am
Yes.
and..welcome to the board!
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby Europanaut » Fri Nov 01, 2013 2:22 am
Thanks again rhino, and thanks for the welcome!
Europanaut
Postby V301H » Fri Nov 01, 2013 3:50 am
I had an Omni 2 and there was a tuning screw in the middle of the rear panel accessible without opening the top. This screw was loose when I bought my unit new which caused it to drift out of tune. After a couple of calls to the factory they figured out what the problem was.
Prophet 5 rev.2, Pro-One, Juno 60, Jupiter 6, Matrix 12, OB8, MS20, Poly 800, CS70M, DX-7, CP35, Casio PX-5S, Hammond C3/M102, Vox Continental/Super Continental, Gibson G101, Farfisa Compact, RMI 300A, Pianet N, Combo Pianet, S770, S760, S50
V301H
Band: The Characters
Postby Europanaut » Fri Nov 01, 2013 5:21 am
Aaaaah.....thanks! There is indeed a TINY screw, accessible via the top panel, and it is connected to L1 on the upper board. I couldn't see the hole in the dark studio, but it was obvious once I got it to the workbench in the shop. OF COURSE, the head of the screw didn't line up with the hole. What IS it with Arp anyway? So great, yet such inconsistent quality.
Thanks again everybody!
Europanaut
