ensoniq sq80 no output
Postby rap and country » Tue Nov 12, 2013 3:30 am
i removed a dying battery from my sq80 about a year ago and it was working 100% until that point
it has been sitting unused/untouched for about a year until i finally ordered a replacement which i installed yesterday
i plugged in the keyboard connector backwards :evil: and blew F3 / F4, but have replaced them and now it appears to power up normally
problem now is i am getting zero output, both from the keyboard and external MIDI
MIDI out seems to be working fine
any ideas on what to check?
thanks in advance
rap and country
Re: ensoniq sq80 no output
Postby synthparts » Tue Nov 12, 2013 3:39 am
You could have blown the CEM3360 output VCA. Do you have another synth with one you can swap in to check? I have them in stock if you need one...
synthparts
Postby rhino » Tue Nov 12, 2013 4:07 am
Strange thing you might try: unplug and clean both ends of the 4-wire cable from the display board to the mainboard. Reason? the volume is controled by a DC voltage from the volume pot to a stereo VCA in the output. Ensoniq had a real problem with connectors corroding - if there is a poor connection on this cable (which carries the volume and data voltages) - you could loose the volume.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby rap and country » Wed Nov 13, 2013 4:35 am
rhino wrote:Strange thing you might try: unplug and clean both ends of the 4-wire cable from the display board to the mainboard. Reason? the volume is controled by a DC voltage from the volume pot to a stereo VCA in the output. Ensoniq had a real problem with connectors corroding - if there is a poor connection on this cable (which carries the volume and data voltages) - you could loose the volume.
this worked! thanks all
rap and country
Users browsing this forum: Google Adsense [Bot] and 9 guests
