aside from Nord Wave, Kronos what synth plays user samples?
Re: aside from Nord Wave, Kronos what synth plays user sampl
Postby Hugo76 » Sun Feb 09, 2014 8:20 pm
chimney chop wrote:
Black Tomorrow wrote:
Cybercardinal wrote:Roland V-Synth
IF you have an older operating system. I don't know about Mac, but as for Windows if you have anything later than XP, you'll need to either get a V-Synth XT/GT to load samples. You can still hook up a mic and record samples directly to a V-Synth.
Personally, I prefer to load samples, and this has been impossible since I switched to 7. :pissed:
aha, i see.
i too prefer to load samples rather than record direct to synth.
i'm running Windows8 so if i got one it would need to be the XT/GT
still, the V-Synth's interface doesn't quite appeal to me.
As I explained above, you do NOT need to record samples into the V-Synth (although that works very well). You load your samples from the computer onto the CF card, and then insert this in the V-Synth. Completely painless and easy
Hugo76
Postby chimney chop » Sun Feb 09, 2014 8:28 pm
sorry for the confusion Hugo, I hadn't seen your post.
chimney chop
Band: boxc, cigarettes after sex
Postby Cumulus » Sun Feb 09, 2014 11:41 pm
A more serious answer but maybe not the easiest is the Alesis QS series.
I remember reading in the manual that you can load your own samples. I've never done it, though.
Cumulus
Band: Cumulus
Postby Hugo76 » Mon Feb 10, 2014 2:07 am
chimney chop wrote:sorry for the confusion Hugo, I hadn't seen your post.
No problem, mate :-)
Regarding the interface I must say it's the best I've ever come across in a synth, so you shouldn't worry about that if you think this synth could fit your needs.
Hugo76
Postby Push-Pull » Tue Feb 11, 2014 3:56 pm
And what about a Yamaha Motif XF ?
The making of my modular... (ok it's in french, but the pictures are easy to understand !)
Push-Pull
Postby ryryoftokyo » Tue Feb 11, 2014 5:17 pm
I have a Blofeld KB and have zero issues with sampling on it. It requires a program on your computer, but it's basically a matter of loading a sample up in the program and hitting "send".
ryryoftokyo
Real name: Ryan
Band: Tarot Sync
Postby chimney chop » Wed Feb 12, 2014 12:02 am
ryryoftokyo wrote:I have a Blofeld KB and have zero issues with sampling on it. It requires a program on your computer, but it's basically a matter of loading a sample up in the program and hitting "send".
can you assign different samples to specific keys on the keyboard or does it take one sample and map that one sample along the whole length of the keyboard?
chimney chop
Postby the synthman » Wed Feb 12, 2014 1:40 pm
Alesis fusion?
the synthman
Alesis fusion?
the synthman
Previous
Users browsing this forum: Mooger5 and 1 guest
