Crumar Performer String Section not working
Postby cprescott08 » Thu Feb 20, 2014 2:41 am
I just purchased a Crumar Performer that was supposed to be Fully Functional.
Unfortunately, that is not the case.
The String section is not producing any sound at the main output.
I do notice if a cable is plugged into the signal out that the string section crescendo and sustain sliders
are operational if that might help in the diagnosis.
Any insight would be appreciated.
cprescott08
Re: Crumar Performer String Section not working
Postby fh991586 » Thu Feb 20, 2014 3:03 am
Forgive me for asking such a stupid question, but is either 16' or 8' buttons pressed?
-Roland TR707
-Yamaha DX7
-DSI Mopho
Gear for Sale: Roland M-OC1, M-BD1
fh991586
Real name: Francis
Gear: Roland Juno 106, JX3P, D50, U220, MVS1, JP8080.
Yamaha Motif Rack.
TherapSid
Postby cprescott08 » Thu Feb 20, 2014 4:07 am
Yes. I've attempted all the different combinations available in the string section.
cprescott08
Postby fh991586 » Thu Feb 20, 2014 5:47 am
Have you opened it to do a visual check, just in case there's something unplugged?
-Roland TR707
-Yamaha DX7
-DSI Mopho
fh991586
Real name: Francis
Yamaha Motif Rack.
TherapSid
Postby cprescott08 » Thu Feb 20, 2014 6:00 am
Yes. Been in the game for sometime now and know how to at the very least check over the BASICS.
Comes with the territory when dealing in vintage gear. I've acquired enough knowledge and experience over the years to expect some issues and perform minor diagnostics and repair. Do you have any experience with the Performer?
cprescott08
Postby rhino » Thu Feb 20, 2014 4:40 pm
If the seller is trustworthy - that is, if the synth WAS fully working but failed in shipment/transport - Check again for cracked PC boards, loose connectors etc.
Looking at the schematic, two failures could kill the strings, but let other features work:
IC2 - a 1458 dual op-amp
IC5 - a 741 op-amp
Both are located on the P-559 board
Scope or audio trace the input and output pins and see if they're both passing signal
EDIT: Never had one so going souly off the schematic: Can you switch the BRASS signal into the delay and verify the analog delay is not dead?
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby cprescott08 » Thu Feb 20, 2014 6:02 pm
Well, I fired it up today and now nothing is working. The lights come on but, no sound output at any of the output jacks. I'm also noticing that the modulation rate led is solid red and is no longer blinking in time with the rate slider.
To answer you question previously I believe the brass was passing thru the delay as the crescendo slider in the string section was effecting the brass sound. Not sure if that's what you were asking though?
At this point I will probably just return it for a refund. I've already been in contact with the seller stating
the issues and fortunately they are agreeable.
Any suggestions on the current issue?
cprescott08
Postby rhino » Thu Feb 20, 2014 8:54 pm
Well, the fact that ANOTHER problem has suddenly cropped up is another (to me) sign of something loose.
Had my shre of Ensoniqs that looked spotless inside, but had that damned grey "mold" on the connectors. Just the weight of the cable moving can make/break the contact.
While you have it open, check the power supply if you have not yet done so.
There are 6 outputs
+24, -24, +12, -12, +9.1 and +6.2
Even integrated regulators can go wonky over time.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby fh991586 » Fri Feb 21, 2014 5:30 pm
cprescott08 wrote:Yes. Been in the game for sometime now and know how to at the very least check over the BASICS.
I'm sorry, but I had no way to know your expertise on the subject! There's a lot of different types of members here...
I own one, and I've removed and cleaned every keys on it, while also fixing a almost broken key (viewtopic.php?f=5&t=62712). I'm afraid that's all I can be helpful about, so nothing considering your problems. Just trying to help... :|
Unless you really want that Performer, I'd deal with the seller to send it back for full refund.
-Roland TR707
-Yamaha DX7
-DSI Mopho
fh991586
Real name: Francis
Yamaha Motif Rack.
TherapSid
Postby voxxline » Mon Aug 03, 2015 12:26 pm
I have the same problem. Did you fixe it?
:cry:
voxxline
Postby sam » Tue Aug 04, 2015 5:58 pm
Start with the power supply
Then check the master osc with a signal tracer or scope.
I have fixed a few of these and all the problems were on the pot board...bad solder joints around the pots.
ms20/50.Andromeda. OBX.
sam
Postby Dr. Phibes » Tue Aug 04, 2015 7:08 pm
The trilogy I'm fixing at the moment (uses lots of the same circuits) had a few dead op-amps that caused similar problems.
Dr. Phibes
