Akai AX80 110v to 240v conversion + need new knobs
Postby GoldSpanner » Fri Feb 28, 2014 4:29 pm
Just bought an Akai AX80 in the UK. It arrived earlier, only for me to find that it's the US version i.e. runs on 110v, and the guy I bought it from failed to mention this.
Whilst a step down transformer would sort it out, in my mind that isn't at all ideal, so is there anything I can do to convert the power section to run 240v? Below are some photos of the transformer/ power section:
I'm also after a replacement data knob and modulation amount knob, if anyone knows where I could get them?
Cheers
GoldSpanner
Re: Akai AX80 110v to 240v conversion + need new knobs
Postby Explorer » Fri Feb 28, 2014 9:36 pm
Explorer
Gear: not enough space here
Postby rhino » Sat Mar 01, 2014 8:13 pm
Sorry. Looked inside all three of mine and it appears that Akai used several different xformers: 110, 110, 120, and multi-voltage 110,120,220,240. All of mine have the 120-volt one, and only two primary wires coming out of the windings. Looks like you'll have to
1) find a used 240 transformer
2) unlikely - find a new transformer that has the same secondary voltages/amps
3) keep using the converter
4) find a small converter (with the correct amps) that would fit into the case. You might even remove the AC filter board to make room.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
