Korg Poly 61 for $300 too much?
Postby synthmaniak » Wed Mar 05, 2014 7:10 pm
Not sure if i should jump on it.
Reason 7, Elektronika EM 25, Korg EX-800, Arturia V-Collection, Komplete 9, G Force String Machine,
synthmaniak
Re: Korg Poly 61 for $300 too much?
Postby micahjonhughes » Wed Mar 05, 2014 7:35 pm
Yes. Difficult interface, no midi, mediocre sound. Save your money.
micahjonhughes
Postby rhino » Wed Mar 05, 2014 7:45 pm
Almost any vintage synth in playing condition should bring $300, BUT:
The P-61 is a strange beast. You should do your homework and even play one before deciding. This dinosaur might not be your cup of tea. Seems to me like Korg cut too many corners on this one.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby CS_TBL » Wed Mar 05, 2014 7:46 pm
Skip it.
I won't say it has no value at all, but $300 buys you something else, more.. better etc.
FM8 vids
CS_TBL
Gear: All "In-The-Box"
Mainly FM8
Postby synthmaniak » Wed Mar 05, 2014 8:07 pm
rhino wrote:Almost any vintage synth in playing condition should bring $300, BUT:
i did see a few youtube vids that i liked. Im really into dark synths, strings.
synthmaniak
Postby synthmaniak » Wed Mar 05, 2014 8:08 pm
CS_TBL wrote:Skip it.
What would you recommend for $300?
synthmaniak
Postby micahjonhughes » Wed Mar 05, 2014 8:09 pm
What are you looking for in a synth?
micahjonhughes
Postby Jabberwalky » Wed Mar 05, 2014 8:28 pm
Not worth it. I really like the sound of it but editing is pretty basic. I'm using mine for the DCO comp
Jabberwalky
Gear: Eps16 | An1x | Minikorg700s | Monologue | Maxikorg | KarpOdyssey | Bs2 | Ultranova | Dw8k | Poly61 | Paia9700s | Volca | Es1 | Er1 | PreenFM2
Band: VARIAR
Postby rhino » Wed Mar 05, 2014 9:14 pm
Depends what you're looking for sound/feature-wise. My 2-cents:
Alesis QS6
Ensoniq ESQ-1, SQ-80, VFX(sd)
Roland JX8p, Juno 1 or 2
Yamaha SY-55, V-50
Korg 01W
EDIT: I'm biased in favor of keys... so I left out rack modules
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby 2manydrummachines » Thu Mar 06, 2014 1:45 am
How is the condition of that Poly 61? It's a funny build, I think it's particle board because it was too keep its price low. There is a Poly61M which has midi. If its in good shape $300 isn't awful. Check how the buttons feel. You could always sample the melodies with the patches you make. Where is this thing for sale?
2manydrummachines
Postby Jabberwalky » Thu Mar 06, 2014 4:16 am
I think it is particle board, but it's the same wood as used on the polysix and the mono/poly. Triggering the arp is also really fun to mess with.
Jabberwalky
Band: VARIAR
Postby ryryoftokyo » Thu Mar 06, 2014 2:25 pm
If it's in really good shape and has the battery changed, I would pay up to $250. Even then, I'd want a couple cables, an effect pedal (it does really well with a nice overdrive), or a stand. See if you can talk him down. In the future, try synthprices.blogspot.com
Programming is very basic and should be intuitive, but don't expect crazy live tweaking or anything like that. Personally, I love the P61 sound and could never remove the two I have from my rig. That joystick is a ton of fun, and chord memory can make some huge leads, and unlike the Juno 60, the oscillators can be tuned. As for the sound, to me it falls in between the Polysix and the Poly 800, so if you like that sound, you'll like this.
You can mod it to have MIDI, but from what I've seen, the mod kits are often as expensive as the synth itself! Regardless, I think it's a hidden gem that can be snapped up for cheap and as we see the older generations of analog polysynths become unobtainable or impractical to own, I think attention will turn to these. Check out what Jexus does with the P61 if you want an idea of what a properly programmed one does.
If you can't get him down, +1 for the Alpha Juno 2. Another DCO board that just screams, but in a whole different way.
ryryoftokyo
Real name: Ryan
Band: Tarot Sync
Postby synthmaniak » Thu Mar 06, 2014 5:08 pm
ryryoftokyo wrote:If it's in really good shape and has the battery changed, I would pay up to $250. Even then, I'd want a couple cables, an effect pedal (it does really well with a nice overdrive), or a stand. See if you can talk him down. In the future, try synthprices.blogspot.com
Thanks for that info!, great info!. Yea he didnt want to go down from $300. I rather wait, from research ive done $300 is a little too much for the unit. Hasnt had battery replaced either. I will continue my search for it. I really like the sounds you can create with this machine. Ive seen several videos on the tube of people playing raw sounds and custom presets.
synthmaniak
Postby synthmaniak » Fri Mar 07, 2014 9:16 pm
ok so i talked him down to $280 but ge said it needs a cleaning, some of the keys need to be pressed on a bit harder than usual.
synthmaniak
Postby ryryoftokyo » Fri Mar 07, 2014 9:38 pm
Way too much. $125 or no deal.
ryryoftokyo
Real name: Ryan
Band: Tarot Sync
Return to Buyer's Guide
