reduble an audio signal
Postby dzcosimo » Wed Mar 26, 2014 10:47 am
Hi
I want to obtain a thing that I thought be quite simple... But I can't find a commercial component that does this!
I want to redouble my audio signal (I play both bass and synths, hence one of these type of audio signals).
For example I want to take my synth output signal and double it. One of the outputs passes from other effects, finally arriving to the mixer, and the other one goes straigth to the mixer (the effect i want to create is like listening two synths that play the same phrasing).
Can anyone help me in finding a commercial component (pedal?) that does this?
Thank you in advance
CosimoDS
Feel free to correct my English at all times, I'd be grateful!
dzcosimo
Re: reduble an audio signal
Postby pflosi » Wed Mar 26, 2014 11:59 am
TS Y-cable :thumbright:
Postby dzcosimo » Wed Mar 26, 2014 12:24 pm
Thank you!
Does it work in any condition? I mean, It is a passive component, hence can I use it only before the amplifier or also after? And is the power of the signal halved or remains the same?
I couldn't find it, because I (foolishly) was sure that an active component was needed.
dzcosimo
Postby madtheory » Wed Mar 26, 2014 8:44 pm
If the split is after the mic pre amp, the mic pre is the "active component" and the cable will not affect the sound in any way.
Band: madtheory
Postby pflosi » Thu Mar 27, 2014 7:14 am
For splitting, it should work fine anyways. You get a small drop in amplitude, but you won't notice that.
DO NOT use it for mixing signals together!
Postby Cumulus » Fri Mar 28, 2014 1:18 am
Some pedals have a dry output as well. That might work for you as well.
Cumulus
Band: Cumulus
Postby Solderman » Fri Mar 28, 2014 11:02 pm
If your instrument is at line-level, why would you not just use an effects send configuration on your mixer for this? The Aux return acts as the second signal.
--Solderman no more.
Solderman
Return to Sound Production
