EMU 4000 Hard disk questions
shadowmaster
Post by shadowmaster » Sun Oct 26, 2014 4:26 pm
hi,
I recently bought an EMU4000 turbo and I think about adding a hard disk.
Currently it has a floppy disk but I want to remove it and install a hard disk instrad.
As I understand it's 50 pin SCSI where I could also use 68 pin or 80 pin with adapters or even SATA disks with the Acard or the AztecMonster.
What are the limits of disk size?
Some new 80 or 68 pin SCSI have 36, 72 up to 300 GB.
And what is the format itself? It is possible to mount it in a linux PC having SCSI card?
Or is it something vintage Macs will detect?
In the manual it says it can format hard disks - so sort of disk management is possible with the EMU 4000 itself.
synthroom
Real name: Kirk
Re: EMU 4000 Hard disk questions
Post by synthroom » Sun Oct 26, 2014 5:02 pm
Check out getting a couple Iomega Zip drives - one SCSI and one USB. Put the USB one on your PC and the other on the sampler. They can be found for $25 or so each. If you want more storage space, look for Jaz drives. (Hooking up a Scsi drive to a PC is a bit tougher but can be done depending on OS.)
It looks like some esi-4000 came with an internal Zip instead of a floppy.
Since it's 50 pins, try a 50 pin SCSI internal drive that's 1 to 2 gigs in size and see if it works. The esi-4000 worked with the Jaz so it can handle at least 1 gig hard drives.
Big Gnome
Gear: E-mu Proteus 2500
Ensoniq ESQ-1
Ensoniq VFX
SCI Prelude
Band: The Nondescript
Post by Big Gnome » Sun Oct 26, 2014 6:29 pm
I don't have too much to add, but I've owned a couple of ESI-32s over the years. They do have the 50-pin SCSI interface (I had some success using a 25-50 pin adaptor with one CD-ROM drive). In my experience, they were very picky about what SCSI devices they would recognize--mine didn't take to all sorts of things including an Iomega zip drive and one or two CD-ROM drives--I ended up getting a SCSI-for-Samplers HD which worked perfectly. So make sure to do your homework before laying out any money.
Some of my c**p
vcs3
Post by vcs3 » Sun Oct 26, 2014 7:51 pm
Post by madtheory » Mon Oct 27, 2014 9:30 am
That would be madness. ESI4000 has SCSI, so a SCSI to SD adapter is all that is required. Much cheaper and easier.
synthroom
Real name: Kirk
Post by synthroom » Mon Oct 27, 2014 2:14 pm
I would also not suggest an HxC - that's for replacing floppy drives, not hard drives.
There is this device that appeared recently:
http://www.codesrc.com/mediawiki/index. ... le=SCSI2SD
I've not used on so I can vouch for it's function, but it's listed as working with several samplers/
gmeredith
Band: Warning Will Robinson
Post by gmeredith » Fri Nov 14, 2014 4:04 am
I have had SCSI hard drives in my ESi2000 and 4000. From memory there is a size barrier of 8GB, and some people have mentioned a 4GB - perhaps depending on the OS firmware version of the sampler. I have had 2GB scsi drives in mine with no problems - usually quantum fireballs or seagates that I ransacked from old apple computers.
I now have SCSI-CF card readers in both of mine - silent, fast, lightweight. I don't know why scsi hard drives have to be so noisy. For getting the samples onto the sampler I have a scsi card in my win98 studio machine. WinXP will handle SCSI but you have to do a lot of setup work to make it do it. Win98 handles it natively and smoothly. You'll need the Esi drivers loaded on the computer for the sampler for it to connect. Load up wav samples with Sound Forge or other editing program that allows single sample dump. Xtrakk works well for loading whole soundfont sf2 banks directly into the sampler over SCSI:
http://home.arcor.de/murmel999/files/xtrakkhelp.htm
Format - it's an Emu proprietary format - you can't see it under windows at least. Yes you can format the drive in the sampler - it's under the disk management menu, the manual should have the instructions. It's been a long while :)
The yahoo esi samplers group has everything in it that you need - programs, ESi drivers, SCSI info etc.
https://groups.yahoo.com/neo/groups/emu ... s/messages
I did a lot of work there on SCSI to USB adapters for it. Join up if you can - not sure if it's administrated any more. If you can't, I have all the resources anyway. Beware there is a nasty troll on the site - you'll know by reading the past posts who it is.
Avoid zip disks if you can - they're annoying and unreliable, I started out with them. You'll soon run out of space with them anyway if you've maxed out your Esi to 128MB RAM (which is a MUST :D )
Cheers, Graham
Post by Ashe37 » Fri Nov 14, 2014 5:32 am
a lot of the 'noisy' SCSI drives are 15+ year old drives form when *all* drives were, comparatively, noisy.
Marco Koeller
Real name: Marco Koeller
Gear: Akai S-2000, Akai S-1100, EMU ESI-4000, Roland D-50, Roland D-110, Roland JD-800, Roland TR-626, Roland TR-505, Roland MC-303, Korg DW-8000
Band: Smooth Genestar, Smooth
Post by Marco Koeller » Sun Apr 26, 2015 10:35 pm
synthroom wrote:There is this device that appeared recently:
Great! Exactly what i was looking for. Thanks!
Music is an universal language, spoke and understood by all....
Free audio netlabel http://www.cyan-music.com
Deep House and Dubtechno http://www.cyan-music.com/smooth
Lounge and Chillout http://www.cyan-music.com/smooth-genestar
Marco Koeller
Post by Marco Koeller » Sun Apr 26, 2015 10:39 pm
gmeredith wrote:I have had SCSI hard drives in my ESi2000 and 4000. From memory there is a size barrier of 8GB, and some people have mentioned a 4GB - perhaps depending on the OS firmware version of the sampler.
Hey, Graham. On the ESI-4000, you also can use HDs up to 15 GB of storage space. I have an ESI-4000 myself extended by an internal 15 GB HD, and meanwhile i have nearly 11 GB stored on that HD. Maybe it is just because i use the latest version of the OS. Dont know why, but it works.
There are some units for sale, like for example this:
http://www.ebay.de/itm/E-mu-ESI-4000-Sa ... 3f4af0ed0e
gmeredith
Post by gmeredith » Mon Apr 27, 2015 12:55 am
It might be a limitation of the card readers perhaps....not that I've ever used a drive that big in it, I've just read people mentioning an 8GB limit with them. That's good to know you have a bigger one running - I also have the 3.02 firmware, so there shouldn't be a problem for me if I ever want to run something that big.
Cheers for that, Graham
Post by Ashe37 » Mon Apr 27, 2015 1:02 am
gmeredith wrote:It might be a limitation of the card readers perhaps....not that I've ever used a drive that big in it, I've just read people mentioning an 8GB limit with them. That's good to know you have a bigger one running - I also have the 3.02 firmware, so there shouldn't be a problem for me if I ever want to run something that big.
FAT file format limit, FAT32 file format limit...
gmeredith
Post by gmeredith » Mon Apr 27, 2015 1:11 am
You mean the ESi? I thought it formatted it to its own EMU proprietary format (which is why you can't see the drive under windows)??
Post by Ashe37 » Mon Apr 27, 2015 2:48 am
oh right i was thinking an E4k... anyway, its likely the same sort of thing.
Marco Koeller
Post by Marco Koeller » Mon Apr 27, 2015 11:31 am
On my research for Samplers with internal harddisks, i found a thread where a user mentioned a SCSI-to-PCI adapter. Dont know, if such a thing exists, but if, it could be another possibility to mount younger harddisks than the SCSI ones.
My first PCs had SCSI drives, so i remember they were pretty loud and noisy back in that time. The Quantum HD which is mounted inside my ESI-4000 doesnt make any noises, by suprise. Only when the HD starts up, but after that, its really quiet.
Last edited by Marco Koeller on Mon Apr 27, 2015 11:33 am, edited 1 time in total.
