Arp 2600 osc scaling.
Europanaut
Post by Europanaut » Sun Jul 12, 2015 4:15 pm
Hello!
I've been working on my 2600 (recapped and calibrated PSU, replacing sliders, key bushings, etc), and am closing in on the biggest issue. Osc 2's scaling is impossible to calibrate. So I assume that something on the osc board needs to be replaced.
Any suggestions on where I should focus first? Any opinions that would help me diagnose this problem?
Thanks
Broadwave
Gear: Kronos 2-88, Fantom 6, Novation Summit, Modal Argon8X, Yamaha MODX6, Behringer Odyssey, Behringer Poly D, BroadWAVE ARP 2600EX.
Re: Arp 2600 osc scaling.
Post by Broadwave » Sun Jul 19, 2015 8:24 am
Hi Europanaut - It could be a number of things...
1. Check the 1.87k Tempco resistor on the VCO module (in my experience, it's the first thing to go)
2. Check the Exp Converter transistor pair (TZ581/81 - you can replace these with 2N3906/04. No need to match them, but the pin-out is different)
3. On the main support PCB, check the 25k CV input trimmer and the 84.5k following it (these two set the 1V/Oct scaling)
That's all I can suggest at the moment... Hope it helps.
Europanaut
Post by Europanaut » Wed Jul 22, 2015 6:38 am
Hey thanks Andy! What a thorough reply! I have to place a parts order for some PSU caps next week, so I'll add some 2600 bits to the package.
This is the LAST thing to fix on this synth, and I'm pretty stoked.
Europanaut
Post by Europanaut » Sun Aug 02, 2015 8:03 pm
Update: Swapped out the tempco, but no change in scaling behavior.
Reginator
Gear: Korg: ARP Odyssey/MS-20 Kit, TTSH: Ver.1/Ver.2, ARP 1601 Sequencer (DIY), Minimoog Voyager, Waldorf Microwave Mk1 rev B, Roland: JP-8080/MC-505
Band: Reginator
Post by Reginator » Mon Aug 03, 2015 1:58 am
Hi, are you sure it's the 4027-1 and not something on VCO 2's main section? Can you try swapping VCO 2's 4027 with a known good one from VCO 1 or 3?
Also if you replaced any VCO 2 FM control sliders you should check to make sure none of them are bleeding any DC offset or modulation to the 4027.
One last thing, check for boards for cleanliness, excess flux or solder bridges.
How far off is the frequency when you press low C and high C and adjust the trimmer? Do you get anywhere near 1600Hz or is it way out?
Europanaut
Post by Europanaut » Mon Aug 03, 2015 6:38 am
Thanks Reginator.
I may try that swap. That would certainly narrow it down. I sure wish they had plugs though, rather than the soldered posts.
As for the sliders, osc 2 had this issue before the slider replacement.
Board is very clean. Like, spotless. Pretty amazing, compared with some of the synths I've bought.
The scaling is WAY out. Not close at all. I can get about one octave, but above that it goes crazy.
Reginator
Band: Reginator
Post by Reginator » Tue Aug 04, 2015 2:51 am
The good thing about the ARP 2600's design is that all three 4027's are exactly the same. After you're able to plug in one of the other 4027's you'll know for sure if it's the 4027 that has an issue or something else in VCO 2.
You can check now for +/-15vdc and ground to the 4027 on pins 6, 7 and 8. This way you'll know if it's receiving good power before you swap them.
Reginator
Band: Reginator
Post by Reginator » Mon Aug 17, 2015 5:38 am
Hi Europanaut, any success with VCO 2? Just curious.
Europanaut
Post by Europanaut » Mon Aug 17, 2015 6:57 am
I haven't revisited it yet. I've been distracted by a major Solina restoration, installation of the Vecoven JX10 upgrade, and recapping/battery replacement on our Source. It just never ends!
Reginator
Band: Reginator
Post by Reginator » Mon Aug 17, 2015 4:54 pm
Ok cool.
