I've spent the last few days resurrecting two jaw droppingly gorgeous 1967 Bruel & Kjaer type 2107 all tube swept band pass filters to life in The Lab. These units are complex and its been a h**l of an intense three days chasing a string of weird faults but having heard one of them almost running after a day of fiddling I was soon very much driven to fully breath life back into them.
Having finally returned the units to life I then set about fitting IEC sockets (B&K used a now very rare mains inlet socket on most of their gear) and making them a little safer and more appropriate for audio use in the studio as these units feature 90 volt low impedance cathode follower outputs with no DC blocking on the ext filter output (confusingly labelled as External Filter Input!) which is a big accident waiting to happen and their main outputs are very hot indeed so I bypassed the final stages, added high voltage metal film blocking capacitors and the beasts are now very much tamed.
Like so much tube gear they have tons of headroom, are surprisingly quiet for their age and distort very beautifully too.
Here is a quick test recording simply sustaining a chord whilst sweeping the filter to reveal its harmonic content. The filter is regenerative (effectively has a resonance control but in steps) and can go right up to 60dB per octave!
