Here are the Emax II Library samples!
Re: Here are the Emax II Library samples!
i just tried to download the files.. and they work! thank you!
but the files reposted after the original downloads went bad.. these are not the ORIGINAL IMAGES
but rather seems to be the SF2's that someone made from downloading the original images..
does anyone have the original images so that i may convert them to Akai S1000 format?
or perhaps Kontakt or whatever other format??
i guess that might be possible to do from the SF2 files as a sourcE? but id rather use the original source images?
Yes, if you read the first post, the OP posted the images, and also posted the SF2 versions.
All those files are offline, but I had downloaded the SF2 versions back then and had them in an archive somewhere, so I dug them out for people who still want this stuff - it's better than nothing. Unfortunately I don't have the images, as I had no use for them and thus didn't download them originally...
- Tekhed66
- Junior Member
- Gear: Roland JD990 / JD800 / XV5080 / SH-01a,
Behringer DM12, Korg Triton Rack / M1 / Radias,
Akai s5000, Yamaha An1x, Kawai K5000s,
Studiologic Sledge 2 - Band: The Creepy Uncles
Can someone please post another (different ) link to these samples? ... the webpage that is hosting them requires you to like and send a message on facebook ... I won't go into the gory details but I don't do facebook or any other social media so I'm not going to go through all of that palava just to get some Emu samples.
If anyone has already downloaded these samples, would it be possible to get a copy?
many thanks.
many thanks.
Hello Folks,
Has anyone succeeded in converting these sample banks from their original Emax II format to EIIIx or E4? I can't read anything prior to EIIIx in my E5000 Ultra (I can't read SF2 either)
I tried to convert them with the tool everybody uses here, but all the samples are only static noize. If I convert all samples to WAV, they sound OK, however, I loose the keymaps and zones which I don't want because they're essential to the sounds.
Please help!
Cheers,
Andreaux
Please help!
Cheers,
Andreaux
hello....I have a emu esi 4000 since 3 month and no emu sound.....If someone can give me a link ....thank you...
sorry for my english but I am french
the link to dowload "Here are the Emax II Library samples!" is dead !
Look at the link four posts up (authored by me). You'll eventually discover that there is much more there than just the obvious Emax, Emax II, and Emulator II factory library stuff.dambuster wrote:hello....I have a emu esi 4000 since 3 month and no emu sound.....If someone can give me a link ....thank you...
Hello there! All all downloads are now inactive and I would very much like to have this. Thanks!
Re-read the thread. Closely.Jamesbaxter55 wrote:Hello there! All all downloads are now inactive and I would very much like to have this. Thanks!
can someone re-up the samples? (in a way that doesnt require external social media)
So interestingD-Collector wrote:Here are all the Emax Library images, free for all to download!![]()
http://www.silveriafamily.com/emax/emax2_downloads.html
Convert them to Akai S-1000, Soundfont SF2, Emulator II,III, IIIx, or between the Emax I or II, or extract wave files using this program:
http://users.skynet.be/emxp/
It works great! I converted all to SF2 and further used Extreme Sample Converter 3 to audition the Soundfonts and convert them to wav or other sampler formats (a huge amount to choose from). Very nice!
Here are the libraries in SF2, packed in self-extracting RAR archives:
Regroupement de prêt
EMAX Library Vol. 1.exe - 55.30MB
EMAX Library Vol. 2.exe - 47.91MB
EMAX Library Vol. 3.exe - 43.90MB
EMAX Library Vol. 4.exe - 25.02MB
Here's a little demo to prove that they work. It is just a quick track I put together, not very polished or anything.
cool thanks
Will these work on an a Elektron digitakt
- meatballfulton
- Moderator
- Gear: Logic Pro X
If you extract them to WAV first, yes.monkeykong1 wrote:cool thanks
