80's Synth Pop
Come here for topics reviewing and sharing songs, tracks, music, synth demos, etc.
80's Synth Pop
Postby NCChao1268 » Sun Aug 06, 2017 8:23 pm
This is a little tune I wrote and recorded; the synths used were the Kurzweil K2000 for the repeating bass/chord sequence, Alesis SR-16 for the drums, Roland JX-8P for the bells and brass, and a Juno 106 for the rest such as the pads and analog sounds. No effects were really used except for some reverb from the mixer.
Feel free to listen and let me know what you think.
NCChao1268
Gear: Kurzweil K2000 fully upgraded
Roland Juno 106
Roland JX-8P
Korg DW 8000
Polysix
Alesis SR-16
Yamaha DX7
Re: 80's Synth Pop
Postby haaplaj » Tue Aug 08, 2017 9:33 pm
Got the 80's beat right. Some timing issues maybe drums vs the bass. Could be a bit shorter, a little more "compact".
Rhythm turns group of sounds in to music.
https://soundcloud.com/haaplaj
haaplaj
Gear: Juno 60, Fantom S, TG 77, JD 990, JX 8P, Wavestation SR
Re: 80's Synth Pop
Postby NCChao1268 » Fri Aug 11, 2017 7:07 am
Thanks, I was really going for the style. As far as the timing, I was pretty sure it was on time since I used a midi clock for the internal sequencer. Maybe I should've turned on the quantize or something.
-Nathan
NCChao1268
Roland Juno 106
Roland JX-8P
Korg DW 8000
Polysix
Alesis SR-16
Yamaha DX7
Re: 80's Synth Pop
Postby gcoudert » Fri Aug 11, 2017 7:22 am
It's the brassy syncopated chords. They need to come forward a bit because of the slowish attack, so that the envelope peak (where the attack changes to decay) falls on the beat. I think the bass may be slightly out indeed; MIDI clock does have its flaws. Nice track nonetheless.
GC
gcoudert
Real name: Gilles
Re: 80's Synth Pop
Postby Tekhed66 » Fri Aug 11, 2017 8:47 am
NCChao1268 wrote:Thanks, I was really going for the style. As far as the timing, I was pretty sure it was on time since I used a midi clock for the internal sequencer. Maybe I should've turned on the quantize or something.
-Nathan
Hi Nathan
The drums and bass sequence aren't locked together so it's missing the beat of the bass+kick ... if you listen carefully from about 57sec onwards, you can hear that the bass timing drifts from the drums so it sort of weakens the foundation of the track... everything else you record on top of that (such as the brass stabs) will sound even more out of time than it probably is.... 80's pop is very rock solid (well... as solid as you could get way back then) so syncing the bass and drums is very important.
What was your master clock in the setup?
If you are recording into a DAW, you can visually check where the midi notes or recorded waveform sit on the timing grid... the midi notes should fall neatly on the timing grid (eg. on the beat) and so should the waveform ... you can hopefully drag and drop the waveform by very small amounts to line up with the timing grid and tighten up the timing.
Hope this makes sense!!??!!
Tekhed66
Gear: Roland JD-990
Roland JD-800
Roland XV-5080
Roland SH-01A
Kurzweil K2000
Yamaha An1x
Korg Triton Rack
Korg M1
Korg Radias
Korg Volca Beats
Akai s5000
Band: The Creepy Uncles
Re: 80's Synth Pop
Postby BackwardsSamurai » Fri Aug 11, 2017 9:22 pm
I know my SR-16 has the timing off. A looong time ago I recorded a 112 bpm track, but I had to slow the drum machine down to 111 bpm since it didn't match up with my DAW.
I do things sometimes. Sometimes they're good things. This might not be one of those times.
SoundCloud: https://soundcloud.com/vauxhumana
BackwardsSamurai
Real name: Anthony
Re: 80's Synth Pop
Postby NCChao1268 » Sun Aug 13, 2017 7:41 am
Unfortunately I don't have the capability to do midi note data too much since I don't have a DAW (dang it), I use old school Audacity. I would best set the quantize to 100% on the K2000 sequencer and the note grid to 1/8th notes since the bass and chord sequence are in eighth notes. Or even rerecording the sequence again. Hopefully quantize will fix the timing issue.
-Nathan
NCChao1268
Roland Juno 106
Roland JX-8P
Korg DW 8000
Polysix
Alesis SR-16
Yamaha DX7
Return to The Listening Lounge
cron
