Here are the Emax II Library samples!
chrisnova777
Re: Here are the Emax II Library samples!
Post by chrisnova777 » Fri Aug 12, 2016 5:48 pm
i just tried to download the files.. and they work! thank you!
but the files reposted after the original downloads went bad.. these are not the ORIGINAL IMAGES
but rather seems to be the SF2's that someone made from downloading the original images..
does anyone have the original images so that i may convert them to Akai S1000 format?
or perhaps Kontakt or whatever other format??
i guess that might be possible to do from the SF2 files as a sourcE? but id rather use the original source images?
desmond
Post by desmond » Fri Aug 12, 2016 9:15 pm
Yes, if you read the first post, the OP posted the images, and also posted the SF2 versions.
All those files are offline, but I had downloaded the SF2 versions back then and had them in an archive somewhere, so I dug them out for people who still want this stuff - it's better than nothing. Unfortunately I don't have the images, as I had no use for them and thus didn't download them originally...
Rasputin
Post by Rasputin » Sun Aug 14, 2016 9:21 pm
Psst...
Emax I/II samples can be found here... in their original formats.
Tekhed66
Gear: Roland JD990
Roland JD800
Roland XV5080
Roland SH01A
Behringer DM12
Yamaha An1x
Studiologic Sledge 2
Korg Triton Rack
Korg M1
Korg Radias
Akai s5000
Band: The Creepy Uncles
Post by Tekhed66 » Tue Aug 16, 2016 12:41 pm
Can someone please post another (different ) link to these samples? ... the webpage that is hosting them requires you to like and send a message on facebook ... I won't go into the gory details but I don't do facebook or any other social media so I'm not going to go through all of that palava just to get some Emu samples.
If anyone has already downloaded these samples, would it be possible to get a copy?
many thanks.
p0531d0n
Post by p0531d0n » Mon Oct 31, 2016 10:49 am
Hello Folks,
Has anyone succeeded in converting these sample banks from their original Emax II format to EIIIx or E4? I can't read anything prior to EIIIx in my E5000 Ultra (I can't read SF2 either) :(
I tried to convert them with the tool everybody uses here, but all the samples are only static noize. If I convert all samples to WAV, they sound OK, however, I loose the keymaps and zones which I don't want because they're essential to the sounds.
Please help!
Cheers,
Andreaux
dambuster
Post by dambuster » Mon Nov 21, 2016 10:32 pm
hello....I have a emu esi 4000 since 3 month and no emu sound.....If someone can give me a link ....thank you...
sorry for my english but I am french
the link to dowload "Here are the Emax II Library samples!" is dead !
Rasputin
Post by Rasputin » Thu Dec 15, 2016 5:58 am
dambuster wrote:hello....I have a emu esi 4000 since 3 month and no emu sound.....If someone can give me a link ....thank you...
Look at the link four posts up (authored by me). You'll eventually discover that there is much more there than just the obvious Emax, Emax II, and Emulator II factory library stuff.
Jamesbaxter55
Post by Jamesbaxter55 » Thu Aug 24, 2017 3:05 am
Hello there! All all downloads are now inactive and I would very much like to have this. Thanks!
Rasputin
Post by Rasputin » Thu Aug 24, 2017 7:18 am
Jamesbaxter55 wrote:Hello there! All all downloads are now inactive and I would very much like to have this. Thanks!
Re-read the thread. Closely.
bo_g
Post by bo_g » Wed Nov 22, 2017 2:15 am
can someone re-up the samples? (in a way that doesnt require external social media)
desmond
Post by desmond » Wed Nov 22, 2017 11:47 am
I updated my links earlier in the thread that Dropbox broke in their recentish update.
- Volume 1
- Volume 2
- Volume 3
- Volume 4
These are the sf2 format versions.
Junior02
Post by Junior02 » Sat Jan 13, 2018 2:40 pm
D-Collector wrote:Here are all the Emax Library images, free for all to download! :mrgreen:
http://www.silveriafamily.com/emax/emax2_downloads.html
Convert them to Akai S-1000, Soundfont SF2, Emulator II,III, IIIx, or between the Emax I or II, or extract wave files using this program:
http://users.skynet.be/emxp/
It works great! I converted all to SF2 and further used Extreme Sample Converter 3 to audition the Soundfonts and convert them to wav or other sampler formats (a huge amount to choose from). Very nice!
Here are the libraries in SF2, packed in self-extracting RAR archives:
Regroupement de prêt
EMAX Library Vol. 1.exe - 55.30MB
EMAX Library Vol. 2.exe - 47.91MB
EMAX Library Vol. 3.exe - 43.90MB
EMAX Library Vol. 4.exe - 25.02MB
Here's a little demo to prove that they work. It is just a quick track I put together, not very polished or anything.
So interesting :)
monkeykong1
Post by monkeykong1 » Fri Feb 23, 2018 4:09 pm
cool thanks
Will these work on an a Elektron digitakt
Gear: Live 9, Logic Pro X
Post by meatballfulton » Sat Feb 24, 2018 7:04 pm
monkeykong1 wrote:cool thanks
If you extract them to WAV first, yes.
