I bought a TR-8 on Sunday and collected my TB-03 on Monday. I wish to connect both units to my computer over USB for audio and MIDI, but have ran into some horrible issues.
The TR-8 via ASIO4All in FLStudio 12 allows me to run each sound over its own mixer channel, which is fine-and-dandy (and pretty much a requirement since it only has stereo out). If I connect my TB-03 and restart the computer, the TR-8 has the "Beyond Logic" status in the ASIO panel. The TB-03 works, however, and I can select its output channel. If I try to change the audio rate, the TB-03 and TR-8 have a status of "Beyond Logic".
If I select "always resample 44.1 kHz <> 48 kHz" then I can get both units working, but the master output sounds like it's been horribly time stretched, and even then both units working is intermittent. From this I'm guessing the TR and TB use incompatible audio rates, which if true, is a big misstep on Roland's part.
I know I can use the input jacks on the back of the TR-8 to route the TB-03's audio to its own track, but I'll be getting a Korg Monologue for Christmas (shared Prime account, it didn't stay secret for very long
I've also tried plugging the TB-03 into the Line-In on the motherboard, but after a few minutes it starts artifacting and generating crunching sounds whenever the 03 makes any form of sound; selecting another input source then switching back to Line-In fixes this, however, so I assume the on-board soundcard is just a bit s****y and its buffer dies a death.
Any advice?
Thank You!
ASIO4All 2.1.4
Windows 10 Professional 1709 Fall Update
Soundcard is the on-board unit built into my ASUS Prime B350-Plus motherboard
--alternatively, I can route the audio via my nVidia 1080 to my monitor that has its own speaker output
