CS-80 Question: 70 ohm Resistance Between+15V and GND
Postby Jonathan40 » Thu Jan 18, 2018 10:31 pm
With the power off, I'm getting a 70 ohm resistance between ground and the +15V card riser supply rail on a Yamaha CS-80 - does anyone know if this is this normal? Not sure if the decoupling capacitors on the new 4000-series sockets are contributing to this.
Jonathan40
Re: CS-80 Question: 70 ohm Resistance Between+15V and GND
Postby synthRodriguez » Fri Jan 19, 2018 12:07 am
By the math that's 214 mA which sounds about right to me.
My CS-50 (with a couple of extra voice cards in it) pulls around 187 mA on the +15 rail when it's running, so a 214 mA value on a CS-80 with all the extra overhead would be a perfectly acceptable value I would think. I wouldn't give it another thought.
The caps shouldn't have anything to do with it regardless with a static measurement.
Scott
synthRodriguez
Real name: Scott
Gear: Moog - Roland - Yamaha
Postby Jonathan40 » Tue Jan 23, 2018 5:43 pm
Thanks, Scott. The 500mA fuse blew on the power supply before I did all this testing, and a tech told me to check for shorts between the 15V rail and ground, hence my question. Need to make sure everything's safe before powering this thing up again.
Jonathan40
Postby synthRodriguez » Sat Jan 27, 2018 7:16 pm
Of course working load and unpowered resistance are two different things so there still could be a problem. Just saying it's not like it's a dead short or something, and at least it makes somewhat reasonable sense.
I get 187 ohm on the CS-50 from the ground rail to the +15 rail. Please let us know what you find.
synthRodriguez
Real name: Scott
Postby Jonathan40 » Tue Jan 30, 2018 1:53 am
synthRodriguez wrote:Of course working load and unpowered resistance are two different things so there still could be a problem. Just saying it's not like it's a dead short or something, and at least it makes somewhat reasonable sense.
Am a little confused - are you getting 187 ohms or mA from ground to +15?
Jonathan40
Postby Jonathan40 » Wed Feb 07, 2018 5:55 pm
Well, I heard from another CS-80 owner, and he's getting 69 ohms from the +15V rail to Ground. Things are looking up!
Jonathan40
Postby Jonathan40 » Fri Feb 09, 2018 5:37 pm
Here are the resistances I'm getting between the power rails on my CS-80 and ground:
+15V = 70.3 Ohms
-15V = 64.5 Ohms
+8.5V = 337 Ohms
-6.5V = 878 Ohms
+10.6V = 540 Ohms
The rails can be accessed on the power supply just behind the output molex connector. The +15V is the brown wire at the top and they go down from there. I'm thinking my -6.5V could be low as a friend is getting 3.95 Kohms on his currently working unit, as well as 456 Ohms on the +8.5.
Jonathan40
Postby lukaskupasz » Thu Apr 19, 2018 2:47 pm
With the power off, I am getting a 70 ohm resistance between +15V card riser rail and ground on my CS-80 - does anyone know if this is this normal?
lukaskupasz
