Korg MS2000 Power supply
Postby SlimeBaal » Fri May 04, 2018 9:59 pm
Hi,
My power supply to MS2000 broke so now i need a new one. im wondering if its necessary to get a official power supply or if i could go with whatever works, and if you have any ide what that would be. Hope you guys know!
Thanks alot
SlimeBaal
Re: Korg MS2000 Power supply
Postby Rasputin » Fri May 04, 2018 11:47 pm
SlimeBaal wrote:im wondering if its necessary to get a official power supply or if i could go with whatever works, and if you have any ide what that would be.
No special power supply is required. HOWEVER, do take extra caution to make sure the polarity is correct! Korg gear is easy to fry by using a substitute power supply that either has the wrong voltage, wrong polarity, or is an AC-AC adapter and not an AC-DC adapter.
In other words, make sure it outputs 9VDC exactly, NOT 9VAC. Not anything higher than 9V. Anything 500mA or higher is fine for amperage. And make sure the polarity is correct because Korg gear almost never has reverse protection diodes to protect against this.
Rasputin
Postby SlimeBaal » Sat May 05, 2018 11:25 pm
Alright! Thank you very much for the answer
David
SlimeBaal
Postby Rasputin » Sun May 06, 2018 12:26 am
SlimeBaal wrote:Alright! Thank you very much for the answer
Welcome.
You can get 2 amp (or about that) adapters with selectable voltage and multiple tips (which can be either tip- or tip+ depending on how you place them on the end of the adapter) at Wal-Mart** for like $10 or so. I'm sure most hardware or department stores would be about the same.
The Korg adapter is garden variety, just take care to match the specs.
** PowerLine brand universal adapter, I think.
Rasputin
Users browsing this forum: Bing [Bot] and 7 guests
