Juno-106 Restoration story/Power Supply woes
Online
Mooger5
Re: Juno-106 Restoration story/Power Supply woes
Post by Mooger5 » Sat Feb 09, 2019 1:47 pm
Poly 1 selected in tezt mode so all voices sound at once, too?
Herrare umanum est.
Online
Mooger5
Post by Mooger5 » Sat Feb 09, 2019 1:53 pm
Nvm, you got another calibrated unit which is flawless. Damned.
Herrare umanum est.
Online
Mooger5
Post by Mooger5 » Sat Feb 09, 2019 2:06 pm
I can only recommend to learn oscilloscope basics to monitor the dac and processor behaviour and compare with the healthy unit.
I might get back to this irritating thing if I remember of anything barely useful.
Herrare umanum est.
The LT
Post by The LT » Sat Feb 09, 2019 2:08 pm
Mooger5 wrote:I can only recommend to learn oscilloscope basics to monitor the dac and processor behaviour and compare with the healthy unit.
Unfortunately, my oscilloscope is a puny Jyetech DSO shell.
I've swapped the CPU for a spare and IC23,24,26. Same thing. :)
I give up. :)
The LT
Post by The LT » Sat Feb 09, 2019 3:41 pm
Mooger5 wrote:Poly 1 selected in tezt mode so all voices sound at once, too?
During Poly 1 mode, the voices immediately fall to lower duty cycle. You can hear them jump as soon as you press the key. During revolver 1-2 mode, it gets shifted after 6 key presses.
Online
Mooger5
Post by Mooger5 » Sat Feb 09, 2019 4:18 pm
Wait... I'm not sure I understand how it's going on afterall. It begins to sound like it's a bad or wrongly set potentiometer during calibration...
Would you mind explaining step by step what happens?
Thanks.
Herrare umanum est.
The LT
Post by The LT » Sat Feb 09, 2019 5:14 pm
Mooger5 wrote:Wait... I'm not sure I understand how it's going on afterall. It begins to sound like it's a bad or wrongly set potentiometer during calibration...
Thanks.
Step-by-step:
Unit turn-on, into test mode.
Load bank 5.
Switch on Poly 1 Unison. Voices IMMEDIATELY fall to 20% and less PWM on C4. Out of bounds for VR-adjustment.
Switch to Poly 1-2 Revolver. Press C6. Press and hold C4. Normal PWM of 50%, well within VR adjustment bounds.
Continue pressing C4. Next voices also hold PWM on 50% without any problems UNTIL we hit it for the 6th time. Then, PWM jumps back to around 20% on C4, which is distinctly heard.
I will shoot a video later.
Online
Mooger5
Post by Mooger5 » Sat Feb 09, 2019 7:08 pm
When voices immediately fall to 20%, try moving the PW fader down to Zero...
Herrare umanum est.
The LT
Post by The LT » Sat Feb 09, 2019 7:50 pm
Mooger5 wrote:When voices immediately fall to 20%, try moving the PW fader down to Zero...
It's not something obvious as this. :) I know it sounds like it, but the PW fader is down at zero, and yes, I've pulled it down. When I do raise it, it only further lowers the duty cycle and doesn't return it to 50%. Faders are new, it's not the panel board. We've measured the CV to the 5534 waveshapers and it was 6.01, remember? :)
Online
Mooger5
Post by Mooger5 » Sat Feb 09, 2019 8:01 pm
Yeah I remember.
Unfixable. Smash it!
Herrare umanum est.
Online
Mooger5
Post by Mooger5 » Sat Feb 09, 2019 8:32 pm
Joking. Sort of. Wouldn´t be surprised if it was some stupid little thing so obvious that we´re overlooking. If you ever find a culprit please report. :ugeek:
Herrare umanum est.
Online
Mooger5
Post by Mooger5 » Wed Feb 13, 2019 10:31 pm
Just noticed in the video the 75% duty cycle has a negative bias when the output should be symmetrical. So another part that´s common to all voices is TR7 and associated resistors. It´s labeled Q7 in the PCB. I´m only guessing that it´s locally regulating a negative voltage to the demux. Maybe the transistor is leaky?
Herrare umanum est.
