Novation Supernova II DAC Repair
shadowmask
Gear: Yamaha: SY85, TG-500, TG-300, MOXF6, FG410
Novation: Supernova II Keyboard & Rack Pro-X
Post by shadowmask » Thu Sep 07, 2017 2:45 pm
Hello,
I am offering a DAC replacement service for the Supernova II series.
A faulty DAC will cause noise / static / silence on the Headphones and Main Outputs 1 + 2.
The owner will need to remove the main PCB from the unit.
I have made a PDF instruction for the Keyboard and Rack version:
https://app.box.com/s/8wo0okdewt4jmsh0zk6gebzu8noyoorf
I am based in the UK. Due to the small weight of the main PCB I can offer this to international customers.
For more details about this service please see my Supernova Repair page at:
https://www.sector101.co.uk/supernova2.html
Many Thanks,
Brian
shadowmask
Re: Novation Supernova II DAC Repair
Post by shadowmask » Wed Oct 31, 2018 8:59 am
Just a note to say this repair service is still available. Over 30 units have been successfully repaired, including additional work to units that have had a previous unfortunate attempted "repair".
Also, the SIIEX24 24 Voice Expansion Card is still available:
https://www.sector101.co.uk/siiex24.html
Brian
Explorer
Gear: not enough space here
Post by Explorer » Wed Oct 31, 2018 7:25 pm
=D> for your work, realy appreciated :agree:
shadowmask
Post by shadowmask » Sat Jun 20, 2020 2:01 pm
I've added a few more repair services for the Supernova II:
Encoders:
A common fault with the Supernova is that the encoders wear out. These are used for the two Data Selection knobs and the Tuning knob. When these malfunctiion the data values on the screen will jump or lag.
DSP Fault:
With a DSP fault the Effects Special LED (keyboard) or Comb Filter LED (Rack) will flash and several of the Part LEDs will be lit. The display will be blank and the unit will not generate any sounds.
FLASH Write Error Fault:
With this fault the Supernova II will display "Flash Write Error !! Switch off & re-try".
Supernova II hangs when Booting:
With this fault the Supernova II will light all the LEDs on the panel and the display will be blank.
For more details about this services please see my Supernova II Repair page at:
Brian
erdem555
Post by erdem555 » Thu Jul 09, 2020 12:38 pm
Hello,
Hi,
I saw you use cs4391a-kzz chip in your website.. It's different than original. Is it works flawless?
I read chip manual:
CS4391A only support 5volt
CS4391 support 5volt and 3volt.
madprof
Post by madprof » Mon Sep 28, 2020 11:04 pm
Yes it works flawlessly. At least in mine it does.
