VP-330 "Human voice" synth recreation?
logix
Post by logix » Wed Jan 13, 2021 10:06 pm
What does it take to re-create the Roland VP-330 "human voice" sounds with a synth of some kind?
I managed to re-create the "Strings" using a Roland MKS-50 using a single sawtooth waveform and fiddling with the filter. This gave me the basic sound, but of course the thing that makes the VP-330 so special is its "ensemble" effect. So recently I bought the XILS Chor'x ensemble plugin which so far (at least to me) has the most convincing VP-330 ensemble effect. That plugin together with the simple MKS-50 tone resulted in something close enough for the strings.
I suspect the human voice sounds (Male 8, Male 4, Female 4) rely on some sort of special filter that isn't found on most regular synths, or is it just a matter of programming things right?
ppg_wavecomputer
Band: ['ramp]
Re: VP-330 "Human voice" synth recreation?
Post by ppg_wavecomputer » Wed Jan 13, 2021 11:20 pm
Multiple bandpass filters and a nice-sounding BBD chorus (preferably based around Reticon SAD1024A or Panasonic MN3005).
Stephen
https://ramp1.bandcamp.com/
logix
Post by logix » Thu Jan 14, 2021 10:01 am
Thanks for the suggestion.
That XILS Chor'X plugin works for me (instead of having to buy/build a hardware variant).
Please explain about the multiple bandpass filters as I'm not familiar with them.
Is it fair to assume that it's based on a very simple sound source (i.e. a sawtooth as with the strings sound) and like you say, multiple filters after that, to shape it into the end result?
ppg_wavecomputer
Band: ['ramp]
Post by ppg_wavecomputer » Thu Jan 14, 2021 9:00 pm
[...] Is it fair to assume that it's based on a very simple sound source (i.e. a sawtooth as with the strings sound) and like you say, multiple filters after that, to shape it into the end result?
Exactly -- the VP-330 is based on some simple waveform like sawtooth or pulse-wave (I don't have the schematics around but maybe someone else does to shed some light?).
This simple waveform is filtered, using multiple resonating formants that resemble the human mouth cavity and speech apparatus.
The resulting sound is still a bit bland and not really interesting, and this where Roland's own BBD chorus comes into play.
Stephen
logix
Post by logix » Thu Jan 21, 2021 12:50 am
Yes, the ensemble effect is definitely what makes things interesting!
Do you have any suggestion as to how to set up the various resonant filters and how many? I was thinking I'd use one of the many filter plugins available along with the mentioned ensemble plugin after feeding a hardware synth (probably my Roland MKS-50 or MKS-70) into the DAW.
I find those synths easy to work with and I suppose analog is the way to go.
celebutante
Post by celebutante » Fri Jan 22, 2021 4:51 am
You might be able to reverse-engineer the formant filters from the service manual (which is easy to find online). You probably could determine the filter types, how many, and the corner frequencies.
The best way is to run white noise through them and look at the curves on a spectrum analyzer, but obviously that's not gonna help you much if you don't have one.
synthesizers.com modular • Sequential Prophet-5 • Roland Jupiter-4 • Korg Delta • Oberheim SEM • Ensoniq SQ-80 • Korg MS-20 • Moog Minimoog • Yamaha CS-15 • Cordovox/Moog "White Elephant"
http://www.mitchellsigman.com
http://www.celebusite.com
logix
Post by logix » Mon Jan 25, 2021 10:01 am
Good suggestions.
Unfortunately no spectrum analyzer available here though.
