Firstly, thanks for the info on a previous post regarding the white gunk around the capacitors on my M1's power board... yes, it was glue... I ended up just desoldering and levering the capacitors off the PCB... it was obviously glue once you had a close up look... all of the removed caps were intact and the PCB was in good condition - no corrosion or other nasties.
Which brings me to my next sad tale of woe....
I recapped all the boards on the M1 and now it won't power up... I double checked all of the soldering and cap orientation, all of the plugs and general bits and bobs but no joy...
I removed the back of the synth and switched it on and noticed a loud(ish) buzzing noise coming from the power board... sounds like an electrical hum but I didn't leave it on long enough to check exactly what's causing it... the onboard PCB fuse is still intact, there isn't any funny electrical smell and fortunately, no blue spark or smoke (!!!!!)
To be honest, I was a little bit surprised that it didn't power up and I've done surgery on many synths over the years and this is the first one that died on the table (so to speak)... I want to check to see if there is power going to the 5V and 12V output but I'm unsure what to do... here is the power board so you know what I'm looking at:
Can anyone pls tell me which pins to check on the 5V and 12V white output plug and can I do this with a bog-standard multimeter? ... I can't afford to take it to a tech so this is a DIY kitchen table job... I just wanted to ask here first before I make a bad job even worse.
Thanks very much for your help.
