Hello,
I purchased an Akai X7000 and the disk drive is not reading the disk. When I insert the media, the drive spins and clicks. I know this is probably related to the belt. Does anyone have any pointers on how to repair this machine? Also, is there a copy of the service manual out there? I've searched the Internet but I haven't found a link to a free version. Thank you.
Akai X7000 Disk Drive Repair
- Hyde
- Real name: Hyde
- Gear: ASR10
EPS16
EPS
Mirage
S2000
ESI2000
SY35
SQ1+
K1000
K2000rs - Band: When Violets Turn Grey
Re: Akai X7000 Disk Drive Repair
Pull the drive & give it a look over. I bought a Mirage sampler in non working condition with a similar issue. I reset the cable, reset anther cable that was accessible, on the drive itself, cleaned it. But, the issue was that there was some fuzz/hair around the shaft that spins, which was causing enough friction to keep the drive from spinning up all the way. I carefully cleared that & I haven't had an issue since.
- oberheim
- Gear: Lots of Korg's, Kawai's, Roland's, Akai's and Emu's. Plus a Yamaha, Nord and Oberheim.
Try YouTube. There are plenty of videos regarding fixing belts on the Japanese Super Famicon systems, which use 2.8" quickdiscs - here's a link to one.
I've got a S700 that needs a new drive, but at the moment I'm sending samples back and forth via midi to an old mac laptop with a copy of Sound Designer 1.6
[RO] SH101, D550, D-110 JV1080, MKS70, S750, S550 [KW] K1r, K5m, R-50 [AK] S700, S1100, [EMU] ESI32, ESI2000, Proteus 1 [KRG] EX800, X5dr, M3r, Wavestation SR, P3, Symphony, DW6000, DSS1, DS-8, Poly61, S3, DDD1, [NV] A Station, [OB] Matrix1000, [NRD] MicroMod, [YAM] TX7
Thank you both for the suggestions. Does anyone have a copy of the service manual? I want to make sure that I have instructions to dismantle/reassemble the the sampler in order to repair the drive.
