Workstation vs. synth
DocDeF4U17
Real name: Daryll
Gear: Yamaha Clavinova CLP-250 with missing legs, Yamaha PSS-470, Korg ElectribER-1
Post by DocDeF4U17 » Tue Jun 13, 2017 11:58 pm
So having toyed around with several work stations ive come to the conclusion that the newer the better as far as "synth" option goes, regular piano seems to sound better on the older work stations, older synths seems to have terrible regular piano, so a new workstation can provide both good piano and good synth, the bigger the better also, if you start to shrink workstations into little keyboards then so does the quality of synth...no matter how new.
If you make good music outside, animals will visit
Real name: Unpronounceable
Band: Eridani V
Re: Workstation vs. synth
Post by Ashe37 » Wed Jun 14, 2017 12:12 am
Yes, buy a Kronos if you want both workstation and synth.
DocDeF4U17
Real name: Daryll
Post by DocDeF4U17 » Wed Jun 14, 2017 8:55 am
Yes thanks I heard, do they make a portable kronos? what compares to the microKorg?
Band: Eridani V
Post by Ashe37 » Wed Jun 14, 2017 8:57 am
nope, the portable is the 61 key.
Gear: Live 9, Logic Pro X
Post by meatballfulton » Wed Jun 14, 2017 12:13 pm
A workstation is a synthesizer. Please write on the blackboard 1000 times :banghead:
You might be interested in the Korg Microstation, no longer made this was an inexpensive workstation with minikeys. They can be found used for $400-500.
SoundOnSound review
Band: Eridani V
Post by Ashe37 » Wed Jun 14, 2017 12:18 pm
Same engine as a Triton, battery power is possible, etc.
DocDeF4U17
Real name: Daryll
Post by DocDeF4U17 » Thu Jun 15, 2017 10:09 pm
https://en.wikipedia.org/wiki/Music_workstation
workstations sound cheap
the korg m1 sounds boring
Band: Eridani V
Post by Ashe37 » Thu Jun 15, 2017 11:59 pm
The M1 is twenty-nine years old. Please use a more modern example when judging sound, etc.
DocDeF4U17
Real name: Daryll
Post by DocDeF4U17 » Fri Jun 16, 2017 5:34 am
nevermind korg m1 sounds phat
http://www.vintagesynth.com/korg/m1.php
