Kawai Q-80 (Q80) Archive & Repository
Rasputin
Re: Kawai Q-80 (Q80) Archive & Repository
Post by Rasputin » Sun May 27, 2018 4:12 pm
salwa wrote:Next goal for me - to find replacement for encoder ;)
Dimensions?
Body dimension: 16mm (W) x 17.5mm (L), maybe?
Shaft diameter: 6mm, maybe?
Shaft height: ?
Total height: ?
As far as newly minted stuff easily available through Mouser goes, I'm thinking ALPS EC16B2410408 is close to correct, but need more information. Also looking at Alpha RE160F-40E3-20A-24P-003 (Mouser #318-ENC160F-24P), depending on shaft height.
Shaft height is probably the total height subtract 6.5mm, so if you measure 26.5mm from PCB to top of encoder then it's probably 20mm. If so, then the Alpha above could be correct.
If it's 31.5mm from PCB to top of encoder then probably 25mm shaft, so the ALPS above could be correct.
If the shaft height is 20mm, this ALPS model may work (don't know what part number this is though!): https://www.ebay.com/itm/Lot-2-ALPS-Rot ... SwCoBakuqi
If it's even shorter than that (21.5mm total height), I'm thinking Bourns PEC16-4215F-N0024 might work.
salwa
Post by salwa » Mon May 28, 2018 9:09 pm
Wow, I didn't expect that - thanks for your help again.
Here it is in all its skipping glory:
It's Alps 331A. Here are my measurements (unfortunately I don't have callipers, so there may be 0,5 mm uncertainity, but I hope encoders are standarized):
Diameter of base: 16 mm
Total height: 28,5 mm
Shaft height (including screw thread): 21,5 mm
Base height: 7 mm
Shaft diameter: 6 mm
Here is how it looks from inside (with main PCB in place)
Casio CZ-1, Elektronika EM-25, Yamaha TX81Z, Roland JV-2080, Novation KS-rack, Korg Poly 800, Casio SK-1, Casio SK-8, Vermona E-piano, Akai S2000, Roland SP 404, Roland TR 505, Yamaha MR 10, Yamaha RX 5 and more
https://www.facebook.com/DOMmusicpl
salwa
Post by salwa » Thu Jun 07, 2018 2:03 pm
An update - I bought encoder (it was actually harder than I thought - most of them didn't have screw thread) and fitted it inside. I have ordered Alps encoder also, but I needed new one badly (for rehersal - the old one deteriorated quickly, it was last call actually), so I bought this Chinese noname. I plan to mount Alps in the end.
As you can see, new encoder is differently oriented (45 degrees turn) and have ACB terminals (original had ABC). It's rather large (I had to bend the connectors), but everything works fine.
Rasputin
Post by Rasputin » Fri Jun 08, 2018 1:35 pm
salwa wrote:I plan to mount Alps in the end.
If/when you successfully get the Alps in there, please come back and do tell what the exact part number is and any special considerations, just as you've done here.
:thumbsup:
pmj
Post by pmj » Mon Jun 25, 2018 8:20 am
Rasputin wrote: Also, looking for a firmware dump of the OS ROM (from U3 - code ROM chip -- 27C512D type EPROM). If anyone can provide this it would be appreciated.
There you go:
https://drive.google.com/file/d/1GX6287 ... QJg7k/view
This is a dump of the U3 chip (NEC D27C512D-15). Not sure what firmware version this is but the label over the crystal reads:
KAWAI
P130C
E5DP
I should point out that I don't have a spare 27C512D here to run the dump to for checking, so you should probably treat this as "at your own risk" if you decide to use it. The unit it comes from is fine and working properly and no errors were thrown up during dumping.
Hope it's useful.
Mooger5
Post by Mooger5 » Sun Jul 08, 2018 8:33 pm
Good thread.
I´ll make a reading on mine and compare checksums tomorrow.
Any research done yet regarding Q-80 vs Q-80EX?
Herrare umanum est.
Mooger5
Post by Mooger5 » Mon Jul 09, 2018 6:05 pm
P130C: 0x0075 55FF - OK
Cheers
Herrare umanum est.
teevee
Post by teevee » Fri Oct 18, 2019 11:54 am
Hi folks,
I have made a dump of revision A and submitted here:
http://dbwbp.com/index.php/9-misc/37-synth-eprom-dumps
yesterday I dumped the firmware for Kawai Q-80EX (Also submitted and will be shown on that page above too later)
My current questions is, where there ever offered any expansions for Kawai Q-80ex?
I noticed two empty IC slots on the mainboard of Q-80Ex. In the Kawai Q-80 you find 4 x HM62256L here. in Q-EX80 you only have 2 and two empty IC slots?
