E-MU EMULATOR II+ Work Log
AlphaC
Real name: Gisle
Gear: Access Virus classic rack Novation Supernova Focusrite Liquid Saffire 56 TC M350 Synthesizer dot com modular synth
Post by AlphaC » Thu Aug 16, 2018 8:21 pm
Hi there :)
This thread will be about my attempt to resurrect this old synth/sampler.
I bought it in non working condition. It looks like its been a victim of a basement flood or something similar. There is lots of mud, dirt and corrosion inside, but all the bits are there.
Any tips, tricks or suggestions are welcome :thumbsup:
Some initial pix.
https://drive.google.com/open?id=1_DrMx ... Ds_JE3Eh2m
https://drive.google.com/open?id=1i_qBZ ... a1NGNCgEGU
https://drive.google.com/open?id=10R_R8 ... GmMAVSFBsv
https://drive.google.com/open?id=1U22gK ... NP0WdwVxzJ
https://drive.google.com/open?id=1cQfsh ... gSVXltFK2n
https://drive.google.com/open?id=1X2CZl ... dN0F1QuoMQ
AlphaC
Yekuku
Re: E-MU EMULATOR II+ Work Log
Post by Yekuku » Fri Aug 17, 2018 12:24 pm
Yikes! Man this is mission impossible!
Before touching the electronics with bare hands you should clean the h**l out of it, I would not be surprised if rodents were partying inside it.
Also dont use ultrasonic cleaner as it can kill vintage parts, remove all socketed ICs and give the pcbs a good wash .
These cheapo DIP14 sockets tend to keep moisture , so make sure you have dried them up thoroughly .
Vintage pots and trimmers dont like washing, isopropyl alchohol is better for cleaning these parts.
Good luck man and let us know how it goes !
It is all about sharing...
AlphaC
Real name: Gisle
Post by AlphaC » Fri Aug 17, 2018 1:54 pm
Yeah yikes indeed. Well the wiring loom have chew marks so rodents have been there. So far I have sandblasted the steel bottom and painted it. The top part has been scrubbed well with a toothbrush. I'm making a new wiring loom with slightly larger size wire. All the pots and sliders are new as they were too far gone to be cleaned. Working on the digital board and the left/right panel boards at the moment.
AlphaC
Yekuku
Post by Yekuku » Fri Aug 17, 2018 5:50 pm
Man you paint like a pro , is this a spray job ? :shock:
Lately I have discovered the fiber glass eraser pens, they are great for removing corrosion from pcbs, connectors etc
I use this one:
What issues have you discovered concerning the electronics so far ?
AlphaC
Real name: Gisle
Post by AlphaC » Fri Aug 17, 2018 6:00 pm
Thanks Yekuku for your input. The digital board went into the ultrasonic cleaner aaaaand the chips oops lets hope they survived the ordeal :beg:
I have opted for replacing all the corroded dip sockets just to be sure they make good contact.
Work in progress - New jacks and midi connectors.
AlphaC
AlphaC
Real name: Gisle
Post by AlphaC » Fri Aug 17, 2018 6:08 pm
No pro spray work here just rattle can's. Etch primer - satin black - 2k clearcoat. It sure looks better than rust =)
I have one of those fiber pens in my ebay cart will order in next round :thumbright:
I have yet to power it up, I need to finish the wiring loom and power supply's before I can check for electrical gremlins.
AlphaC
AlphaC
Real name: Gisle
Post by AlphaC » Sat Aug 18, 2018 12:25 pm
Pulled another 12 dull and green sockets today, but ran out of 18 pin dip sockets :blink:
Reginator
Gear: Korg: ARP Odyssey/MS-20 Kit, TTSH: Ver.1/Ver.2, ARP 1601 Sequencer (DIY), Minimoog Voyager, Waldorf Microwave Mk1 rev B, Roland: JP-8080/MC-505
Band: Reginator
Post by Reginator » Sat Aug 18, 2018 3:10 pm
Hi AlphaC,
Nice work so far on resurrecting your EII+. You've done a lot of work and it looking great. I have a new cleaner in my arsenal by MG Chemicals called Safety Wash II. It does the job and it's safe! I recently used it on a Casio CZ-101 that I brought back to life.
I also did major surgery to my newly acquired EII+HD from a fellow member: added a USB port (Emuser), removed the hard drive and all the SCSI components, burned some EPROMS, installed a Floppy Emulator drive, repaired a broken key, cleaned every button contact, replaced the LEDs with new colors. I love impossible tasks!
AlphaC
Real name: Gisle
Post by AlphaC » Sat Aug 18, 2018 6:54 pm
Hi Reginator thank you for your kind words!
Your EMU looks like a minter. I do plan to add a Emuser and a floppy emulator when I see signs of life.
I have a bottle of flux and watermark remover ready for the final wash in the ultrasonic. That paste flux gets so nasty sticky when it cools down :lol:
Left panel before refurb.
Left and right after replacing all the switches, pots and sliders. I have a new display incoming.
AlphaC
Reginator
Band: Reginator
Post by Reginator » Sat Aug 18, 2018 10:06 pm
Keep going AlphaC! Soon you'll cross the finish line!
AlphaC
Real name: Gisle
Post by AlphaC » Sun Aug 19, 2018 8:05 pm
Reginator wrote:Keep going AlphaC! Soon you'll cross the finish line!
Thanks!
Do anyone have an image of the scanner disk for setting up the wheels?
AiphaC
Reginator
Band: Reginator
Post by Reginator » Sun Aug 19, 2018 8:32 pm
AlphaC wrote:Do anyone have an image of the scanner disk for setting up the wheels?
AiphaC
The yahoo Emulator II group has a lot of files. That's where I got the binaries to burn my EPROMS. https://groups.yahoo.com/neo/groups/emu ... -list/info
Also there is a forum dedicated to all Emulator versions, and you can get expert help. http://eiiiforum.com
Note to Mods: please delete the links if this is not appropriate.
AlphaC
Real name: Gisle
Post by AlphaC » Wed Aug 22, 2018 8:35 pm
AiphaC
Thanks Reginator. I will check out the Yahoo group. I am a member of the eiiiforum, no hits there as of yet.
AlphaC
AlphaC
Real name: Gisle
Post by AlphaC » Wed Aug 22, 2018 8:39 pm
New cable harness made.
Old.
New.
AlphaC
AlphaC
Real name: Gisle
Post by AlphaC » Thu Aug 30, 2018 9:19 pm
More crustiness =)
Old wonky wheels with a hint of rodent activity.
Slightly tidier.
Next up is the a new harness.
AlphaC
